Alloy Wheel Adaptors??
Postby big col » Tue Oct 07, 2008 8:13 pm
I saw some one on here had some adaptor plates made up by an engineering firm, and was selling them. Does anyone know who it was?? As i wanted to get a set made up at the college where i work, and needed the measurements. Any help would be greatly appreciated, Cheers,Big Col.
big col
Re: Alloy Wheel Adaptors??
Postby custom » Tue Oct 07, 2008 8:16 pm
i have a set of alloy adapters what wheels are you wanting to fit mine were made to 112pcd so i could fit audi alloys
custom
Postby MrMPuk » Tue Oct 07, 2008 8:34 pm
Luke has posted a cad drawing with all the measurements on.
Postby MinorMatt » Tue Oct 07, 2008 8:36 pm
Was just looking it up to give the link....
viewtopic.php?f=13&t=15807&st=0&sk=t&sd=a&start=90
thats to fit 5x112 PCD wheels... modify to suit your desired PCD
Postby big col » Tue Oct 07, 2008 8:57 pm
OH POO! My wheels are six stud. Looks like i must have f***** up. :roll: :roll: Can you do a drawing for six stud wheels? As I'm s*** wiv compooters :D :D
big col
Postby MinorMatt » Tue Oct 07, 2008 9:40 pm
I believe you will have problems finding wheels that will fit under the arches with adaptors on a 6 stud! Also 6 stud axles are much heavier duty, I would not be happy running adaptors on mine!
Postby big col » Tue Oct 07, 2008 9:50 pm
I'm not using my van to carry anything, just a recreational vehicle.
big col
Postby carnut1100 » Wed Oct 08, 2008 2:56 am
big col wrote:OH POO! My wheels are six stud. Looks like i must have f***** up. :roll: :roll: Can you do a drawing for six stud wheels? As I'm s*** wiv compooters :D :D
Can do. I did the 3D CAD model from the drawing posted on that thread.
If you give me a few measurements I can bash something up for you.
I need the PCD of the Transit 6 stud pattern.
I need the diameter of the Transit studs.
I need the diameter of the studs you want to run.
I need the diameter of the head on the studs you want to run.
I need the diameter of the portion of the stud where it is pressed into the adapter/flange.
I need the diameter of the spigot poking out from the centre of the hub.
I need to know how far the spigot pokes out fron the face of the brake drum.
I need the diameter of the face of the brake drum.
I need the PCD of the wheels you want to fit.
I need the inside diameter of the centre hole in the wheels you want to fit.
I would like if possible to know the diameter of the inside face of the wheels you want to fit.
If you have a preference for the thickness of the adapter/spacer let me know otherwise I will do it at 20mm or 25mm.
If you could do a quick measure of that and PM them to me I will have you a 3D CAD model and a set of working drawings within a few days.
For things like the drum diameter and how far the spigot pokes out a ruler is fine but for the critical bits see if you can get a vernier caliper onto them.
Dimensions in millimetres preferred but I can work in inches if required.
1979 Mk2 Truck Project thread here
carnut1100
Postby MrMPuk » Wed Oct 08, 2008 11:29 am
Trouble is the 6 stud axles are much wider than the 5 stud ones and with adaptors your wheels will have more sticking out than under the arch.
Postby GAZ666 » Wed Oct 08, 2008 12:23 pm
wouldnt it be possible to put on arch extensions of some sort? i wouldnt mind a set of alloys on mine, and i have the chance of a set of 22" with low profiles that only come in at about an inch taller than standard tyre :)
GAZ666
Postby MinorMatt » Wed Oct 08, 2008 12:46 pm
The wheels and tyre both have to have a load rating up to or exceeding the axle load. Thats the law whether you are using the vehicle commerically or not
Postby towncruiser » Thu Oct 23, 2008 4:05 pm
4
towncruiser
Postby speedy » Sat Oct 25, 2008 8:26 pm
Has nobody ever fitted wellers to the 6 stud axle?
speedy
Postby Luke » Sat Oct 25, 2008 8:28 pm
speedy wrote:Has nobody ever fitted wellers to the 6 stud axle?
i saw a mk2 pickup ages back and that has 6 stud wellers on it so it can be done :D
Postby speedy » Sat Oct 25, 2008 8:30 pm
we use them for racing...transit stud pattern,(Some use a morris LD pattern) but between 8" and 14" wide usually lol.
speedy
