Here it is all assembled using the FWD vw caddy gearbox casing front half.
The clutch was a custom remanufactured one from National Clutchs, if you explain what your doing they can make up the disc quite easily. Also had to have the ford clutch release bearing shaft turned down the the same diameter as the vw one so that I could use the clutch arm easily. The standard type 9 spigot bearing o/d 21mm is the correct size to to tap gently into the vw flywheel ( putting the bearing in the freezer first helps) which is handy! The only other thing to do was to chop off the diff casing from the vw gearbox.
The next problem is the clutch slave cylinder as the type 9 is in the way, looks like I may get away just angling it but I'll see. Master cylinder already in place...
left hand mount
window for wardy, may be keeping it for a while though
Thats all for now, will keep updating!
