roof mounted monitors
Re: roof mounted monitors
Postby executivetravel » Thu Nov 13, 2008 3:24 pm
huh
didnt know fords require a wiring loom adapter from ford to iso...
ggrrrrr
executivetravel
Postby executivetravel » Thu Nov 13, 2008 10:13 pm
would anyone with a swb transit VAN like to tell me what the gap is inside the roof ribs bewteen the bottom of the rib and the skin of the roof please, before i screw into the rib unseen?....
ive a 1"x1" square section ally tube, some headlining and the lower rib section to screw into using a 1.5" self tapper....
executivetravel
Postby MrMPuk » Thu Nov 13, 2008 10:15 pm
Duuno about the gap between the panels but there is a good 1 inch gap between the headlining and the ribs in the middle section of the van.
Postby executivetravel » Thu Nov 13, 2008 10:23 pm
screwing up into the ribs though, would prefer not to let the rain in...
executivetravel
Postby executivetravel » Mon Nov 17, 2008 4:56 pm
anybody know of a reasonable mobile TV aeriel for window or roof mounting?
the lead for "TV ant" is almost the same as the RCA phono's for audio/video
executivetravel
Postby executivetravel » Thu Nov 20, 2008 12:24 pm
thgis job woulda been a POP ....IF id had all the right connectors and adapters...
ordered a s-video extension lead (cos the monitor has a lead to carry 2 audios plus +/-) and its not an s-video lead but the very similair looking PS/2 keyboard type plug......doh
PLUS, ive had to shunt the monitor back to clear the rear aircon controls which means the front end of the mounting plate only is screwed to the roof rib, im considering a bolt up into the roof to stabilise 100% the monitor but hestitating to go through the roof skin, wont be visible but seems unfortunate to have to do it, cant get into the headling though to do anything else.
executivetravel
Postby captain hook » Thu Nov 20, 2008 6:46 pm
Stick it to the roof......
Sikaflex comes to mind :wink:
captain hook
Postby Luke » Thu Nov 20, 2008 10:53 pm
captain hook wrote:Stick it to the roof......
do that except bond a bracket to the roof and bolt it to that so you can remove it :D
Postby executivetravel » Fri Nov 21, 2008 11:35 am
ive got 2" of headlinig, interior lights and roof air vents in the damn way
but i see what you mean
ta
executivetravel
Postby MrMPuk » Fri Nov 21, 2008 11:39 am
Can you not take the headlining down then you will be able to fit brakets behind it?
Postby executivetravel » Fri Nov 21, 2008 2:26 pm
youve not seen the headlining in a tourneo i take it?...
a "bonded" bracket would be open to coming away when the screen is pulled down
a "screwed up" screw wouldnt hold the base of the monitor when it was pushed back up
der.....
two bolts, from above the roof/outside, straight down, with a small plate inside/below the headling with a nut above it and a nut inside the monitor to trap bolt, plate and monitor base...no movement of anything
all this to watch the simpsons....
executivetravel
Postby MrMPuk » Fri Nov 21, 2008 2:36 pm
I have the same headlining in my van!
If you do it with the right stuff as suggested you wont have a problem.
Postby executivetravel » Sun Nov 23, 2008 11:41 am
1. i bet the roof has sound deadening glued to it
2. i wonder what the depth of a rib is
3. i think a 1/8" thick ally plate with one end formed into [_____________ (like that) would be best
the base of the plate fixed one end to th erib and the other end glued/bonded to the roof
executivetravel
Postby captain hook » Sun Nov 23, 2008 1:06 pm
If you think Sikaflex isn't strong enough..........
Try pulling your windscreen out!
Aston Martin use a very similar adhesive
to bond their roofs on!
I think that says it all really!
captain hook
Postby executivetravel » Sun Nov 23, 2008 1:40 pm
captain hook wrote:If you think Sikaflex isn't strong enough..........
ahh, id googled SILKAFLEX.....
any idea what product of the sikaflex range would be the best?
i just had a brainwave
the ultimate would be to bond up a short section of actual transit roof rib where needed...
executivetravel
