Whell adapters
Whell adapters
Postby vidma&tas » Mon Dec 15, 2008 11:14 am
Hi,
I've done blueprint for rear wheel adapter from original bolting places to 5*4.5in, dimensions in bp in cm.
Does anyone have any suggestions about part, if it would be made from aluminium about strength or anything else?
(New wheel connecting with adapter through old bolting places so nut will be hidden in adapter)
vidma&tas
Re: Whell adapters
Postby cartooner » Mon Dec 15, 2008 12:55 pm
I would use steel in this case. Aluminium is good for spacers but not for this application.
cartooner
Re: Whell adapters
Postby Luke » Mon Dec 15, 2008 1:01 pm
agreed :D steel is best in my opinion :D
Re: Whell adapters
Postby Beefy » Tue Dec 16, 2008 9:35 pm
cough cough..
ive had ali hub adaptors on my mk2 for over a year and 20,000 miles.
i even made them myself.
they roll along lovely, no cracks, no bending just as good as steel... and they dont rust...
i dont pootle along either, i drive it every day, farm tracks, potholes etc.
its been fine.
dont be mean to ali, its our friend :)
up to you though...
i used 1" plate HE 15 ali. if it helps
VAN-TENDO A GO-GO!
Beefy
Re: Whell adapters
Postby Luke » Tue Dec 16, 2008 9:38 pm
when i designed mine i went to get them as thin as possable - they were 20mm too :D i think ali is better suited to wider ones where weight is more of an issue :D
Return to Mk 1 & 2
