Windscreen rubber fitting Mk1
Postby Trinny » Wed Dec 17, 2008 10:23 pm
Windscreen fitters and I failed to fit my new windscreen rubber today
(using original screen,v.good cond, as we couldn't get the inside top rubber over the metal lip)
So I searched the forum on the subject and Fred warns against this mixing of old and new ....why?
The Fitters coming round Sat to have another go.....
any tips?
Trinny
Re: Windscreen rubber fitting Mk1
Postby rover » Wed Dec 17, 2008 10:27 pm
Salt free liquid soap and string :wink:
Rover.
rover
Postby Neil » Wed Dec 17, 2008 10:28 pm
change your fitter :wink:
Neil v6
Neil
Postby Trinny » Wed Dec 17, 2008 10:33 pm
The fitter came recommended.Thankyou
At least I know my windscreen surround is solid now!
Helpful tips still welcome
Trinny
Postby WINDSCREENGUY » Wed Dec 17, 2008 11:29 pm
oh dear them pattern parts are a bitch to fit
formally grey van man.
WINDSCREENGUY
previously grey van man
Postby transitgeoff » Thu Dec 18, 2008 8:55 am
:lol: sure are, i watched you lose a few pounds fitting mine :lol: :lol:
transitgeoff
Postby MK1Chris » Thu Dec 18, 2008 2:10 pm
The fitters had a problem re-fitting my old screen with brand new rubbers.
They let the rubbers soak in warm water for a while and that helped to soften them a tad. There was still an alarming amount of "persuasion" required with fists etc to get the screen in :o
Luckily, using fitters meant that they were covered by their insurance. If I tried to fit the screen myself, and cracked it... £££££'s to find a replacement!
MK1 CI Motorhome.
Original 2Litre V4 and 4 Speed Manual with 29k on the clock (now up to 31k!)
Rusty problems soon to be sorted. See my progress in the projects section... http://fordtransit.org/forum/viewtopic.php?f=27&t=28696
MK1Chris
Postby madmark » Thu Dec 18, 2008 2:48 pm
i can remember haveing mine done it was a bitch of a thing to get it to sit right! :wink:
but a good fitter will be able to do it in the end! :wink:
Postby travlinman » Thu Dec 18, 2008 4:32 pm
grey van man wrote:oh dear them pattern parts are a bitch to fit
if you cant get genuine what else you suposed to use or do
travlinman
Forum fool
Postby 214si » Thu Dec 18, 2008 5:25 pm
i need a new rubber, but i have a choice of 3 options
i can remove one from the spare mk2 we have (which may not be any good once removed)
order one from rejel
or order one from another supplier
i mean i wouldnt like to use the 2nd hand again, and ive heard rejels arnt the best, but as stated above what are we to do?
as long as it goes in and seals then well isnt it all good?
214si
Postby madmark » Thu Dec 18, 2008 8:06 pm
if i had another mk2 i would only fit the mk1 rubber with the chrome insert ,unless you want to keep that cloth handy for mopping the dash! :wink:
and one otherthing about the bitch of a mk1 rubber it dont leak! :wink:
Postby 214si » Thu Dec 18, 2008 9:07 pm
is that because of the 'ears' on the mk2 rubber which causes it to leak, also why would an aftermarket mk1 rubber not leak and a mk2 leak?
214si
Postby bron y aur » Thu Dec 18, 2008 11:12 pm
A up Trinny, i recognise ya avatar :D , btw hows suzanna.
Anyow fit the rubber to screen, feed some strong string around and in the groove where the metal lip will fit leaving an overlap on the bottom edge, place screen/rubber centrally onto bottom aperture lip (string inside), from outside exert gentle pressure working from bottom, then sides, when the screen no longer moves in, then pull the string (one end) slowly while pressure is applied to the area that the string is pulling the rubber lip over.
Do ya get me drift, this all works better if you can work with the rubber warm, but watch inside for the rubber pulling over the lip, then.........jobs a good un.
214si wrote:is that because of the 'ears' on the mk2 rubber which causes it to leak, also why would an aftermarket mk1 rubber not leak and a mk2 leak?
, the reason why mk1 rubbers dont leak is the silver locking strip.
i started with nothing, still have most of it left
bron y aur
Postby 214si » Thu Dec 18, 2008 11:43 pm
so the silver insert, spreads the rubber and pushes it in to the metalwork thus creating a tighter seal?
or am i just totally barking up the wrong tree
214si
Postby bron y aur » Thu Dec 18, 2008 11:52 pm
you got it 214 si. :P
bron y aur
Return to Mk 1 & 2
