help and info coswort 2.9 into my transit
Postby kevvy79133 » Sun Dec 28, 2008 6:29 pm
i have a 2.9 cosworth bob engine with all wireing engine and gear box
was looking at putting it into my 2.8 capri.. as i have done it before
but now considering putting it into my transit pickup..
will it bolt to the gearbox on the transit or how do you convert..
any help help help help help help
kevvy79133
Re: help and info coswort 2.9 into my transit
Postby Luke » Sun Dec 28, 2008 6:41 pm
to fit it to the transit MT75 gearbox you will need the very rare svo adapterplate and flywheel :D or modifly pinto ones :)
have a search throught the progress report section theres a few of us who have done it different ways :D
Postby Guy88 » Sun Dec 28, 2008 6:54 pm
not been done with a BOB iirc, pats is the problem on these
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby bortaf » Sun Dec 28, 2008 7:42 pm
you can use the BOA loom but i beleive you loose the vairiable inlet tract, theres quite a few BOBs about in other cars :wink:
try here
http://maddoldbugger.powweb.com/forum/ 8)
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby kevvy79133 » Mon Dec 29, 2008 4:06 pm
wireing not a problem it may sound extrem but i am gona
use the whole wireing loom from the car including fuse box ech
it just the gear box problem im stuck on...thanks for all your
help sofar
kevvy
kevvy79133
Postby MrMPuk » Tue Dec 30, 2008 1:41 am
Coswort?
Postby Luke » Tue Dec 30, 2008 9:34 am
kevvy79133 wrote:wireing not a problem it may sound extrem but i am gona
help sofar
kevvy
if your doing that doesnt is need any sensors off the autobox :?: have you actually had it running this way before and on a manual :?: :D
Postby kevvy79133 » Thu Jan 01, 2009 4:54 pm
yes have had this engine runing on a frame in the garage
took a lot of work but it ran without a gearbox connected..
but not for long... as only down pipes and lambada sensers
verry loud.......................................
kevvy79133
Postby AndyG » Fri Jan 02, 2009 1:13 am
Luke wrote:if your doing that doesnt is need any sensors off the autobox :?: have you actually had it running this way before and on a manual :?: :D
Luke's right :!:
On the A4ldE, the ECU receives data, like how hot or cold the transmission is and also if it's overheating :!:
The ECU takes this information and can (lower) stop the engine from delivering FULL power :!: :evil: And we can't have that :!: Can we :?: :wink:
Postby Luke » Fri Jan 02, 2009 10:46 am
Luke's right :!:
there must be a way of 'fooling' the ecu into thinking everything is ok - shorting sensors out etc. :?: :D
Postby OxtonyxO » Fri Jan 02, 2009 10:48 am
you can but each sensor gives a resistance back. So you would need to bridge with a resistor not just a link also this resistance may change at different speeds :?
OxtonyxO
