help with fuel pump
help with fuel pump
Postby the.little.fatboy » Sat Jan 17, 2009 2:22 pm
hi i have a 2002 52reg 75psi fwd t280 transit van i have taken the fuel pump off and put it back on agian can some1 tell me how to self bleed it off the key all help welcome thanx jim :x
if it brakes fix it if you cant fix it scrap it and buy a ford transit
also collecting scrap metal in northampton and milton keynes area's
the.little.fatboy
Re: help with fuel pump
Postby winterheating » Mon Jan 19, 2009 12:51 am
did this not work?
viewtopic.php?f=5&t=38617
it wontstart if youve drained battery to much.
if you dont have the hand primer you could put the flow pipe to pump into a can of diesel to get it running. aswell as cracking injectors off one by one.
winterheating
