My Landliner
Re: My Landliner
Postby jay » Fri Jan 23, 2009 6:20 pm
and through the back of the workshop.....get the engine hot makes it easier and keep the clutch pedal down while warming up..stop the engine and restart in first gear with clutch down makes sure there is nothing in front of you..if it still dont work go back then stick it into first gear while keeping clutch pedal down..if it still is stuck then take the gearbox off..
mk1 connect tourneo
jay
Re: My Landliner
Postby Chaz&Saz » Fri Jan 23, 2009 6:39 pm
Sorry Jay, tried that too.............Any other suggestions welcome
1972 Built, 1973 Registered, Land Liner V6
1967 Triumph Herald - Bethany
1976 Triumph Dolomite
Chaz&Saz
Re: My Landliner
Postby jay » Fri Jan 23, 2009 6:55 pm
try it a few more times....But not that hard of a job to remove the gearbox.At least that way you can put a new clutch in place and then u will know its got a good clutch...and it gives you a chance to check the under neath fully as well.
mk1 connect tourneo
jay
Re: My Landliner
Postby Chaz&Saz » Fri Jan 23, 2009 7:06 pm
Will do in the morning Jay thanks.
Does anyone have a patten/template for a carpet for the front cab?
Chaz&Saz
Re: My Landliner
Postby Chaz&Saz » Fri Jan 23, 2009 7:36 pm
Few more questions....
Where is the engine number? so i can find out if it is a van or car angine and set valve clearences timing etc.
Are down pipes available? If not do the 3 branch manifolds from a Capri fit?
What other models of Ford/Transit use the same gearbox? The gearlever is mounted on the side.
I have a few electrical gremlins to sort out is there a fusebox? So far the indicators and wipers do not work and one high beam is burnt out tho i have a few spare sealed beams in the end i will go for H4 conversion.
None of the electrics in the back work i have found the other battery and hooked up another with some jump leads but nothing seems to work. Did the landliner have a split chatging system so both batteries were charged?
Cant think of anything else but im sure there will be more questions
Thanks for your help
Charlie
Chaz&Saz
Re: My Landliner
Postby madmark » Fri Jan 23, 2009 7:44 pm
no way to down pipes you have to make your own :? :? capri ones will fit then make a system after that :wink:
the engine number is normaly on the block on the small lip about the oil filter, it will be very hard to see as normaly they get painted over and oily ! :wink:
the gearbox will be standard transit g type box! :wink:
Re: My Landliner
Postby Chaz&Saz » Fri Jan 23, 2009 8:10 pm
thanks. Found a gear box on ebay but its says its from a diesel and dont look like ours so i take it, its a different type. Thanks
Chaz&Saz
Re: My Landliner
Postby madmark » Fri Jan 23, 2009 8:20 pm
why do you need a gearbox?????????
your gearbox should look like this ~!
Re: My Landliner
Postby Chaz&Saz » Fri Jan 23, 2009 8:56 pm
want one as a spare, i've heard stories, that they break easily and seen as the one on ebay is reconned and never fitted, thought it'd be worth it.
Do you know if the 185 r 14 are a suitable upgrade from the 165's?
Chaz&Saz
Re: My Landliner
Postby jnwferguson » Fri Jan 23, 2009 9:51 pm
re.your jammed clutch jack up the rear fit axle stands under axle put in gear and start engine then depress brake pedal the clutch plate will have rusted to the flywheel you may have to rev it and stand on the brakes a few times but it will shock loose
cheers jim.
mk2 camper
mk2 4x4
mk2 ci travelhome camper
the devil is in the detail
jnwferguson
Re: My Landliner
Postby Chaz&Saz » Fri Jan 23, 2009 10:18 pm
just done that too, thanks tho. Me thinks we'l have to take box out.
A standard bumper will fit mine wont it, even its from a flat nose? Im thinkin about takin my bull bars off and just puttin the bumper back on but cus of the bull cars, the one thats on now is cut into 3
Chaz&Saz
Re: My Landliner
Postby travlinman » Sat Jan 24, 2009 1:14 am
put back axle on some good axle stands start it up in gear get it upto 30..40 mph with clutch held down slam brakes on hard that will do it
travlinman
Forum fool
Re: My Landliner
Postby Chaz&Saz » Sat Jan 24, 2009 11:01 am
well i suppose this isn't working cus i've only got the hand brake to break with. I still cant get the drums freed off.
How heavy is the gear box? Am i likely to get flattened taking it out?
Chaz&Saz
Re: My Landliner
Postby Neil » Sat Jan 24, 2009 12:45 pm
transitgeoff wrote::( dont wanna put the mockers on this but i think its a breaker :( unless your a good welder :D
:roll:
Neil v6
Neil
Re: My Landliner
Postby Chaz&Saz » Sat Jan 24, 2009 12:55 pm
it's not worth breaking just cus i cant get the front brakes unseized. Im not letting this go! I could say, you might change your minds once you see the pics but i dont know. You all sound like your allergic to rust! I know im not keen on using the mig but ill do it! Its too good to scrap, definately!
Chaz&Saz
