alanwh wrote:Hi Rich,
I would think the NA LDV pedal would be the one !
Why have you decided to ditch the EPIC ?
The manual pump is without a doubt the fit and forget bullet proof option
but It wont be half as smooth running as the EPIC and in your van it has the benefit
of the better LDV ECU.
alanwh wrote:With regards to the belt pulley, its the same from the EPIC so don't worry!
Did you get the Bosch injector pipes to suit, or are you going to bend the EPIC ones ?
Al
supadik wrote:SH1T!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! The furking fuel feed and return pipes are different. The epic has screw in type ends at the pump and the bosch needs banjo type unions and my local scrappy wont let me have any cos he recons that it make the engine worthless for export???????????!!!!!!!!!!!!!!!!!!!!! GIT!
