Frag wrote:If its FIP watchdog signal lost,and your talking about the van in your sig e.g a front wheel drive.
Either you have a wiring fault between pump & pcm (wiring prone to rubbing thru & breaking on starter rear case) or it could be the pump itself.
If its had a pump,wiring could be the fault,people fit pumps for this reason when it`s wiring thats buggered.![]()
On final code clear did you just end up with that one code?
Frag wrote:Easier to do from underneath (otherwise its manifold off really).
Also easier to drop starter motor off too,before disturbing owt,have a very close look at wiring loom to pump where it comes down over end casing of starter (left hand end looking from front).
Lift it up off starter & see if its been rubbing,will be more apparent once starter is off,chafes thru outer loom & cloth/tin foil like insulation,water gets into the wire it corrodes & breaks.
Just strip insulation of that very short section above starter end plate & have a look while your messing,check connector onto pump also for issues.
Frag wrote:Not very,done possibly 5/6 but most people don`t know about it or sort them........
They chuck £700 of pump then labour at them first........
Frag wrote:You could simply check resistance between pump connector & pcm connector using a normal multi-meter.
PCM plug comes off easily under bonnet,1 10 mm bolt,still need pump connector of though.
Also check for continuity on same wire to earth with both plugs off,could be earthing on starter.
I`ve found & cured all mine without doing any of that & going for visual inspection first,sometimes if fault is intermittant or comes & goes with engine movement ,resistance check`s won`t show fault.
Only if wire is completely broken/open circuit........
sootymax wrote:nice one m8 if i were you id take the whole engine loom off so you can do a better repair on the bench
Users browsing this forum: Bing [Bot], Google Adsense [Bot]
