mk3 swb diesel 2.5 to a pinto questions etc
Postby intransit89 » Sat Feb 07, 2009 8:07 pm
hello i will be hopefully geting a mk3 J reg swb low roof transit ex bt sprayed red body work a bit gone but chassis is ok :D .
right question is,
the van is a diesel,
but my mate wants engine and box and prop shaft for his auto pinto so will the engine loom and dash loom be ok for puting the pinto in this mk3 van?
+ where does the pipes come out on a pinto rad?
+ does the ignition need any thing to make the pinto work?
and other thing is does the brakes still work from the servo to the vac pump back of alt on a pinto?
cheers rob
ie my mate has a camper mk3 pinto with auto box and he will have the diesel engine in so i will be having the pinto stuff for this red one but maybe want to try and get hold of a adptor plate for the mt75 to pinto :D just to get the van running till i find a other petrol engine :twisted: :wink:
intransit89
Re: mk3 swb diesel 2.5 to a pinto questions etc
Postby Guy88 » Sat Feb 07, 2009 10:22 pm
East job mate
I wouldnt bother thou if the body's shot
Pinto rad has top hose to the passenger side
Engine loom is different
TBH i wouldnt bother :wink:
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby jay » Sat Feb 07, 2009 10:29 pm
servo vacumn comes from the inlet manifold..........tbh as well dont bother if its a bit to far gone.loom is easy to do if u can get the compleate loom,but hassle if u cant get it
mk1 connect tourneo
jay
Postby MinorMatt » Sun Feb 08, 2009 12:04 am
I've seen a pic...
The bodywork doesn't look bad, just a few grotty spots
Postby intransit89 » Sun Feb 08, 2009 12:59 am
heres the only pic i got
intransit89
Postby transitgeoff » Sun Feb 08, 2009 1:16 am
the petrol gets its vaccum from the inlet manifold not from a pump like the diesel, the pinto and diesel rad inlet and outlet are the same :wink:
transitgeoff
Postby intransit89 » Sun Feb 08, 2009 1:23 am
transitgeoff wrote:the petrol gets its vaccum from the inlet manifold not from a pump like the diesel, the pinto and diesel rad inlet and outlet are the same :wink:
should be geting van and engine etc for 100.00 when daves finshed :D
intransit89
Postby intransit89 » Mon Feb 09, 2009 11:13 pm
intransit89
Postby Muttley » Wed Feb 11, 2009 9:39 pm
The 2.1 is not a standard ford lump, it is an overbored 2000 pinto. I am no longer fitting a pinto in my mk3 so have all the kit to fit a pinto into a mk3 :wink: :D
Expert burns receiver.
Bodger Extraordinaire!!
Fallen in love/hate with Mk6s
Muttley
Return to Transit Talk
cron
