Do I need a 6 speed 'box?
Re: Do I need a 6 speed 'box?
Postby Luke » Tue Feb 24, 2009 1:07 am
has anyone got the data for the mk7 boxes with the ratios for each gear so we can be 100% sure if 6th is the same as 5th or not :?:
Postby winterheating » Tue Feb 24, 2009 1:17 am
yeah that would be better,
as you get 4 different ratio diffs on 6 speed so one would equall same engine speed as a 5 speed with appropriate diff :!:
winterheating
Postby coconut » Tue Feb 24, 2009 9:13 pm
I can only get the ratios for FWD 5 and 6 speed boxes
5 speed VXT-75
First gear 3.80
Second gear 2.136
Third gear 1.345
Fourth gear 0.921
Fifth gear 0.674
Reverse gear 3.727
The 6 speed VMT6 is a bit more confusing though :!:
Nope I couldnt work out the copy and paste for that lot, so you'll have to make do with a picture :)
coconut
Ford Technician
Postby Luke » Tue Feb 24, 2009 9:27 pm
so the final drive ratio changes :? i didnt know that :idea:
i take it the rear drive box doesnt do that :lol:
Postby coconut » Tue Feb 24, 2009 9:35 pm
I presume its cus the 6 speed has 3 shafts as opposed to the 5 which has 2 shafts, maybe?????? I dunno :lol:
coconut
Ford Technician
Postby Luke » Tue Feb 24, 2009 10:09 pm
i dont suppose you have an exploded diagram :D be interesting to have a look inside one :idea:
Postby coconut » Tue Feb 24, 2009 10:47 pm
not a very good pic im afraid
coconut
Ford Technician
Postby Luke » Tue Feb 24, 2009 10:50 pm
thank you :D
and ............. yeah thats nice and complecated :lol:
i suppose and advantage would be the wear is spread over more gears - so the final drive gears in 5th and 6th wont get any use in the other gears :idea:
Postby coconut » Tue Feb 24, 2009 11:07 pm
just to complicate it a bit more
System Operation
Power transmission route in 1st gear
The 1st gear wheel is positively connected to the 1st to 4th gear output shaft by the 1st/2nd gear synchroniser assembly.
Power transmission route in 2nd gear
The 2nd gear wheel is positively connected to the 1st to 4th gear output shaft by the 1st/2nd gear synchroniser assembly.
Power transmission route in 3rd gear
The 3rd gear wheel is positively connected to the 1st to 4th gear output shaft by the 3rd/4th gear synchroniser assembly.
Power transmission route in 4th gear
The 4th gear wheel is positively connected to the 1st to 4th gear output shaft by the 3rd/4th gear synchroniser assembly.
Power transmission route in 5th gear
The 5th gear wheel is positively connected to the 5th/6th/reverse gear output shaft by the 5th/6th gear synchroniser assembly.
Power transmission route in 6th gear
The gear wheel of the 4th/6th gear drives not only the gear wheel of the 4th gear but also of the 6th gear.
The 6th gear wheel is positively connected to the 5th/6th/reverse gear output shaft by the 5th/6th gear synchroniser assembly.
Power transmission route in reverse gear
The reverse gear idler is welded to the 1st gear wheel. It is constantly engaged with the reverse gear wheel (shown separated for clarity).
The reverse gear wheel is positively connected to the 5th/6th/reverse gear output shaft by the reverse gear synchroniser assembly.
:shock: :shock: 4th & 6th use the same gear, my head my head :lol:
coconut
Ford Technician
Postby BART » Wed Feb 25, 2009 10:51 am
Six gear on my 135 is 28 mph/ik rpm. 70mph on the gps is 2450rpm.
Had a 115 5speed and 70mph was 2900 rpm.
BART
Postby winterheating » Thu Feb 26, 2009 11:23 pm
BART wrote:Six gear on my 135 is 28 mph/ik rpm. 70mph on the gps is 2450rpm.
what diff did it have though?
winterheating
Postby aln101tf » Thu Feb 26, 2009 11:52 pm
My 53 Mk6 RWD 330 does 2700 at 60mph, and I think nearly 3200 at 70mph. It has a 5.13 to 1 diff and new tyres. 75mph would be about 3400 I suppose, but I dont do that very often as it just wastes fuel and really doesn't get you there any quicker :( . Sounds roughly about the same revs as yours, so I'd guess you've got the same diff.
I thought it was a bit revvy at first, and wanted to see if I could change this, but it tows beautifully so now I'm going to leave as is.
Alan
Mk6 125/330 swb lr rwd 2.4L remapped.
Mk7 115/330 swb lr rwd 2.4L remapped.
Custom Tourneo swb 125ps 2.2L remapped to 170ps and final drive gearing lowered 12% to T340.
Custom Tourneo L2 Auto 130ps 2.0L Forscan remapped to ford 170ps
aln101tf
Postby winterheating » Thu Feb 26, 2009 11:56 pm
as yours is only 5 speed though we need to find out what diff BARTS 6 speed has to compare the 5 and 6 speed.
winterheating
Postby winterheating » Mon Mar 16, 2009 12:11 am
coconut wrote:just to complicate it a bit more
System Operation
does this gearbox have different oil to the standard 5 speeds :?:
winterheating
Postby coconut » Mon Mar 16, 2009 10:38 pm
winterheating wrote:does this gearbox have different oil to the standard 5 speeds :?:
According to etis VXT-75 the oil spec should be WSD-M2C200-C and a VMT-6 should be WSS-M2C200-D, so I would say yes :!:
I got an engine out of a 140ps FWD at the minute and the gear oil smells like rear axle oil to me, but thats a different spec again so I dont think its the same stuff :)
coconut
Ford Technician
