wheel arch flares
Re: wheel arch flares
Postby WINDSCREENGUY » Sat Mar 21, 2009 10:42 pm
i was thinking jumbo rear plastic arches or what about trying connect arches for size??
formally grey van man.
WINDSCREENGUY
previously grey van man
Postby grannygranada » Mon Mar 23, 2009 11:22 pm
Try Mk1 golf gti trims from german and swedish! Maybe mk1 ashtray GTE wheel arches too! I had a go at flaring my audi 90 quattro arches. Dont do it!! The car cost £100, it went tits up, so I scrapped it!
Its all about offset!
grannygranada
Postby MattBlackMinibus » Tue Mar 24, 2009 8:15 am
[quote="grannygranada"]I had a go at flaring my audi 90 quattro arches. Dont do it!! The car cost £100, it went tits up, so I scrapped it!quote]
Oops!!
I'll be looking at it carefully before I take hammer to steel then :!:
MattBlackMinibus
Postby Luke » Tue Mar 24, 2009 9:52 am
MattBlackMinibus wrote:Just fitted 7" wellers and they're sticking right out of the arches
can you still open the sliding door :?:
Postby MattBlackMinibus » Wed Mar 25, 2009 9:57 am
Luke wrote:can you still open the sliding door :?:
Yep. The door just slides along the rubber of the tyre.
I reckon if the tyres were wider then I'd have trouble!
MattBlackMinibus
Postby Luke » Wed Mar 25, 2009 10:42 am
same as mine now on 15" suzuki rims and my transit 14" wellers were the same but on 195 tyres the door jammed - i'm pritty sure it's legal like that no need to flare the arches unless you want to :D
Postby MattBlackMinibus » Wed Mar 25, 2009 10:51 am
Luke wrote: i'm pritty sure it's legal like that no need to flare the arches unless you want to :D
Yes, I believe you're right Luke.
The tyre is past the arch, but the tread is just within, so I think that makes it legal.
I want to do the arches for aesthetics,
cos at the moment it looks wrong with the wheels poking out.
MattBlackMinibus
Postby Terry » Fri Mar 27, 2009 8:39 pm
Killjoy here
Before you go battering / flattening out the arches under 'curl' , check about sharp edges prodruding.
I don't think Ford (or any of the others) curl the panels under just to collect dirt, I believe the law has something to say on the matter. Hence the Minis (proper Minis) having the plastic edging round the wheelarches and protruding seams.
Pallet Puller
Terry
