Something like this AndyG
Postby AlanN » Tue Mar 24, 2009 12:13 am
Ive had little idea to add a couple of clocks to the window pillar, but AndyG has asked me too this one for him instead. Great I thought, Ill bugger up his one, before I do mine :lol: :lol: :lol:
Not that easy when you only got millimeters on each side... anyway, I got a start tonight
Re: Something like this AndyG
Postby MR BigBeefy LDV Guru » Tue Mar 24, 2009 12:25 am
this is going to be boringly perfect
everything you do is perfect m8
Transit dreamer!
Postby BigNeil » Tue Mar 24, 2009 12:27 am
good to get a practise one !!
BigNeil
Postby AlanN » Tue Mar 24, 2009 12:37 am
MR BigBeefy LDV Guru wrote:this is going to be boringly perfect
hell no! ever heard of photoshop :lol:
Postby MR BigBeefy LDV Guru » Tue Mar 24, 2009 12:43 am
:lol: :lol: :lol: :lol:
m8 your work is some of the best out there
Transit dreamer!
Postby AndyG » Tue Mar 24, 2009 12:44 am
That's 8) 8) 8) mate :!: Carry on :!: :D
Postby BigNeil » Tue Mar 24, 2009 12:48 am
is that what a dremel looks like ?
BigNeil
Postby AlanN » Tue Mar 24, 2009 12:54 am
Thats the maximum angle without going through the sides, so I hope the clock face is a nice angle to read... Plastic filler tomorrow
Yep thats a dremmel type tool, hundreds of atatchments, cuts, grinds, sands, polishes everything :D
Postby AlanN » Tue Mar 24, 2009 12:55 am
Thanks, but youve not seen it for real :lol: but I do try. I just enjoy doing something different :!:
MR BigBeefy LDV Guru wrote::lol: :lol: :lol: :lol:
Postby Luke » Tue Mar 24, 2009 9:40 am
i've seen your work alan and it's top notch 8)
where is the pod from :?: we're after doing something similar in the mk6 cossy van - at the moment it's got a boost gauge wedged in the dash top document tray :oops:
Postby AlanN » Tue Mar 24, 2009 10:09 am
AndyG supplied the bits... the pod is fibreglass, which makes a little harder to bond together, plus there isnt much room for it to go in and give it an angle so that the face is pointed towards the driver...
Ive got a double one here for myself and I dont think its going to fit in, may have to be 2 singles... Ive started to fill the joint this morning before work, but Im running out of isopon bumperfill and body filler doesnt stick really well enough. Im worried it will crack being two matterials, which expand at different rates in direct sunlight, but we will see :D
Postby AlanN » Tue Mar 24, 2009 8:26 pm
Well, Ive had a few problems tonight.... the fibreglass I used to join the parts together, isnt bonding to the plastic pillar cover, even after using solvents to soften the plastic! Its now sitting in the shed with some epoxy resin in the joints, should be set in a few hours. Not sure what else I can use. :(
Postby darkbluevanman » Tue Mar 24, 2009 8:37 pm
AlanN wrote:Well, Ive had a few problems tonight.... the fibreglass I used to join the parts together, isnt bonding to the plastic pillar cover, even after using solvents to soften the plastic! Its now sitting in the shed with some epoxy resin in the joints, should be set in a few hours. Not sure what else I can use. :(
I sometimes use a glue stick and a hot screwdriver melt everything together (both bits of plastic + glue stick), on certain types of plastic I use the same hot screwy with super glue! don't get a wiff or get and eye ful... nasty!
darkbluevanman
Postby AndyG » Tue Mar 24, 2009 9:16 pm
Luke wrote:i've seen your work alan and it's top notch 8)
Pod is from a Fiesta :!: :D
At first, I thought it might simply fit, but that was just wishful thinking :lol:
Postby AndyG » Tue Mar 24, 2009 9:19 pm
AlanN, if it doesn't work out, do not worry about it :!: :!: :D
I know (from what you've already said) that it might not be possible, due to the pod being fibreglass and the A trim being plastic :!:
