Andyg wrote:Automatics are the Best !
Rolo wrote:Andyg wrote:Automatics are the Best !
Only if you want to pay more for the vehicle in the first place;
or you don't want to drive as fast as the vehicle could with a manual transmission;
or you don't mind the extra weight;
or like spending more money on fuel to travel at the same speed or distance;
or you like spending lots of money changing ATF every single year;
or you like spending a lot more money on repairs that would cost next to nothing with a manual transmission;
or you don't care about not being able to push start it if your battery is flat or the starter motor gave up the ghost;
or you like having to buy a new transmission every 100k miles or so.
Other than that automatics are best.![]()
Andyg wrote:and also get 115PS SWB as What Van? Tested it![]()
Andyg wrote:4EB '95 '96
4EC '97+
Code is stamped into the block lower edge behind the oil filter.
Also look at the white label on the plastic timing cover on the right hand side looking straight down.
Also look in the passenger foot step area for a plate which should give you confirmation of the engine code.
BEST OF LUCK![]()
