2.0 DOHC ENGINE IN TRANSIT
Postby spanners » Fri Apr 14, 2006 11:07 am
IM LOOKING TO REPLACE MY 2.0 PINTO AUTO WITH A DOHC 4 SPD AUTO ANYBODY DONE THIS AND HOW HARD (ELECTRICS AND GEARBOX ,PROP,ELECTRICS) THANKS LADS
spanners
Postby bortaf » Sun Apr 16, 2006 9:20 pm
try and get the engine loom from a granada they are seperate and easyer to wire up :D
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby rs7performance » Mon Apr 17, 2006 12:22 pm
i wouldn't bother really the dohc are no where near as good as a pinto
there a bit faster but there unreliable and costly to fix
if you want a bit more power i would go for a 2.0i pinto
but its up to you having hada few dohc sierras scorpios granadas etc there not a good engine unless you spend all your money on them all of the time
rs7performance
Postby Luke » Mon Apr 17, 2006 12:49 pm
rs7performance wrote:i wouldn't bother really the dohc are no where near as good as a pinto
im a fan of the Dohc - i do agree what you say pinto's will take more abuse but dohc's are reliable if looked after and you get better mpg with a dohc aswell!! :D
Postby spanners » Sat Apr 22, 2006 6:23 pm
thanks lads just back of me hols which is easyer to fit im not to good with wiring :oops: and does anybody no the score with prop shafts thanks
spanners
Postby Luke » Sat Apr 22, 2006 6:34 pm
wiring is tricky on either the DOHC inj or the pinto inj - if your not good with wiring, it's fairly strait forward using a granada loom but if you hit a problem then you will be in trouble.
the prop if you use the same gearbox then you should be able to keep the same prob - i'd have thought :? :D
what type gearbox is yours?
Postby spanners » Sat Apr 22, 2006 7:46 pm
hi my gearbox is only a 3 spd i was hoping to transplant the 4 speed out off a granada at the same time ? do u no wat the gearbox codes are ie ,is the 3 spd a c3 or worg warner 35 or are they the same ? tar
spanners
Postby Luke » Sat Apr 22, 2006 8:10 pm
im not up on the autoboxes - personally hate the things :wink: :lol:
but....... i do believe the same 4 speed autobox fitted to the granada ADL4 ?? if this is the case a standard transit stick and prop will be available and should be an easy fit!!! :D
Granada auto boxes
Postby Terry » Sat Apr 22, 2006 8:25 pm
There are 2 types of autobox in the Granada/Scorpio
A4LD and A4LDE which is the later 'electronic' box
hence the 'E'.
I have a Scorpio with the E box, and if you get a good one
they are fine ( not great), if you get a bad one they are a pile of dogs
droppings. They are VERY expensive to repair (which is why there
are so many cheap Scorpios about ) and there are very few
places that actually KNOW what they are doing (as opposed
to being able to read the OBD 2 diagnostic machine), or more often the
STAR reader (mk 1 electronic reader, which is no good on a mk 2 equipped car !)
There is/are so many sensors/ electronic inputs, that make it so complicated.
Personally given the choice I would go for a manual box.
Pallet Puller
Terry
Postby AndyG » Sat Apr 22, 2006 8:36 pm
:idea: THREE actually :!: and that's wthout their individual differences :!:
A4LD. A4LDe. and A4LDE.
If you're going automatic you may be better off with the A4LD as this one is not controlled electronically.
It has a vacuum controller on the side instead of an electronic socket.
You will no doubt have to change the prop shaft or have it altered because the C3 box is shorter.
Postby spanners » Sat Apr 22, 2006 8:37 pm
i need an auto got some thing wrong with my hips (avasular nercouis) driving a manual kills me :x :oops: i will sort it out some hows :idea: are well come :?:
spanners
Postby Luke » Sat Apr 22, 2006 8:46 pm
A4LD thats it - was this fitted to the sierra aswell as the granada :?:
that was the one fitted to the transit Rover has just fitted one to his - he had a few probs tho read abouth them in this thread!!! :D
Postby Andrew E » Sun Apr 23, 2006 8:53 am
The DOHC came with carbs on certain models too if its easier, but its fair to say that the granada loom seperates easier than the sierra one. Also the head gasket has a few weak spots so worth costing in, as is the plastic guide between the chain.
Andrew E
Postby Gunslinger » Sun Apr 23, 2006 12:18 pm
if its any good to ya, i saw this earlier
2 litre ford transit 8v twincam engine for rebuild
you are looking at a ford transit engine with ancillories 2litre needs timing chain
CLICK HERE FOR AUCTION
Code: Select all
Ends: 24-Apr-06 12:23:05 BST
Gunslinger
Postby spanners » Sun Apr 23, 2006 7:32 pm
:oops: im a bit scared off the wiring the gearbox sound like a night mare will the DOHC OR PINTO INJECTION ENGINE fit to my c3 gearbox and will it be ok acc,top end etc ? :twisted:
spanners
cron
