Which brake shoes
Which brake shoes
Postby excalibur » Wed Jun 03, 2009 7:38 pm
The brakes on the front of my camper are grinding so want to order some new shoes
Looking at the online dealers there seem to be 3 sizes
standard axle
15 seater bus
heavy duty axle
I know it aint a bus so assume I have a choice of two. Am I right in thinking the standard will be the SWB and the heavy duty the LWB?
Its for this
Although if I look here and put in 1973 Transit it says I have discs which I know is wrong
http://www.brakepartssuperstore.org.uk/contents/en-uk/d676.html
excalibur
Re: Which brake shoes
Postby Luke » Wed Jun 03, 2009 8:18 pm
standard :D should be these :arrow: http://www.brakepartssuperstore.org.uk/ ... d6716.html :D
just to check on the calipers is there 1 piston each side? if theres 2 its not them :? :lol:
Postby excalibur » Wed Jun 03, 2009 8:32 pm
Thats wrong, I have drum brakes not discs
excalibur
Postby Luke » Wed Jun 03, 2009 8:34 pm
whoops :oops: :lol:
give in then all mine had disks :D
Postby madmark » Thu Jun 04, 2009 1:36 pm
Luke wrote:whoops :oops: :lol:
all converted then luke? :lol:
Postby Luke » Thu Jun 04, 2009 7:30 pm
oh yeah forgot about the fire van :roll: :oops: :lol: that doesnt count as i've never had the wheels off :lol:
Postby excalibur » Mon Jun 08, 2009 10:34 pm
OK, bit of a problem now.
Measured the shoes, and it turns out to be a standard axle.
Have tried to buy online only to be told they are obsolete, these are the ones I tried to get. Same on a couple of other sites
http://www.brakepartssuperstore.org.uk/contents/en-uk/d6710.html
Any idea what motor factors will be able to help? Supposed to be going on holiday in a couple of weeks so need it sorting urgently
excalibur
Postby hodgson4711 » Wed Jun 10, 2009 1:56 pm
have you tried e-bay there are brake shoes on there all the time
hodgson4711
Postby Chaz&Saz » Wed Jun 10, 2009 7:21 pm
Are your baseplates ok? If so get them re-lined Got a set done a year ago cost £30. took 2 days
1972 Built, 1973 Registered, Land Liner V6
1967 Triumph Herald - Bethany
1976 Triumph Dolomite
Chaz&Saz
Postby excalibur » Wed Jun 10, 2009 7:59 pm
Tried evilbay and they only have the LWB ones. Found a place down the road from work who will reline the old shoes. £40 but can pick them up in the morning.
The linings I have are fine, just one has come off the shoe and another was just starting to. I have some shoe rivetts but they are for commercials. If they had been smaller I would have drilled them and rivetted them back on
excalibur
Return to Mk 1 & 2
