Retro fitting electric windows.
Postby CaptiV8ted » Tue Jul 21, 2009 7:10 pm
Had a search, but can't quite find the answer I need. Where will the loom ends for electric windows be if fitted, so I can have a look for them? Will they be in the doors themselves or up under the dash? What sort of conector should I be looking for?
Many thanks,
Nick.
CaptiV8ted
Re: Retro fitting electric windows.
Postby MinorMatt » Tue Jul 21, 2009 7:25 pm
Assuming you have a mk5 (the only one mk3.4.5 that would be fitted with leccy windows) you need to take off the fake speaker cover in the footwell. If there are 2 large round plugs there you have the high spec loom and ford leccy windows and other toys will plug straight in. If you have a single plug you dont have the high spec loom.
There may be a loom in the door but its unlikely unless you have an alarm central locking or electric mirrors
Postby CaptiV8ted » Tue Jul 21, 2009 8:14 pm
That's interesting.... Sorry, I should have said, it i a mark5 (1999). It does have central locking ad 'leccy mirrors - but no leccy windows :? Seems an odd combination....
So tomorrow I pull off the speaker covers!
CaptiV8ted
Postby MinorMatt » Tue Jul 21, 2009 8:30 pm
ang on...
if it has leccy mirrors there is an extremely good chance you already have the correct loom in the doors
Postby CaptiV8ted » Tue Jul 21, 2009 10:15 pm
That would be genious. All I need then is a suitable donor scrapper!
CaptiV8ted
Postby MinorMatt » Tue Jul 21, 2009 10:19 pm
you will want the door cards, switches and motor. Everything else is the same.
Its not difficult to fit but you need to drill out some pop rivets and put new ones in
Postby trigger » Wed Jul 22, 2009 9:25 am
I have a pair of correct door cards and switches but no motors, the door cards are ok not brilliant but they would be a start.
Mk5 Transit the daddy
trigger
Postby Wildy » Wed Jul 22, 2009 5:26 pm
I have a pair of motors.....
Some people are like slinkies, not really good for anything
but they bring a smile to your face when pushed down the stairs.
Wildy
Postby CaptiV8ted » Wed Jul 22, 2009 5:53 pm
trigger wrote:I have a pair of correct door cards and switches but no motors, the door cards are ok not brilliant but they would be a start.
Why are the door cards not brilliant? My interior is otherwise mint....
CaptiV8ted
Postby trigger » Thu Jul 23, 2009 4:08 am
Drivers side one has a plugged up hole where a manual winder was temporarly fitted and the passenger one has a small tear near the bottom, like i said they would be ok until you found some better ones
trigger
Postby CaptiV8ted » Tue Jul 28, 2009 5:07 pm
Ok, here's the latest. I've had the door cards off, there are no spare plugs. Then after taking off the false speaker cover in the footwell (driver's side) I found 3 multi plugs.
The large multiplug (3 wires visible, bottom) has shed loads of wires going into it, but only 3 coming out. Am I right in guessing an electric window set up will use another plug here, brimming with wires? I've tried to id the wires from the Haynes book, but as I have central locking and leccy mirrors, the circuit diagrams aren't great.
So, I call on those with the knowledge, can I plug into this socket with a electric window loom when I eventually find one??
I've also looked at the fusebox and there is a 30A fuse in the right slot for electric windows - could I be onto a winner?
CaptiV8ted
Postby MinorMatt » Tue Jul 28, 2009 9:35 pm
Yes the loom for electric everything in the doors plugs into that one with 3 wires leaving...
everything you need in the van loom is there - but if you want electic mirrors you need the electric mirror switch too. I have a spare if you cant get one with your mirrors
Postby CaptiV8ted » Wed Jul 29, 2009 8:40 am
MinorMatt wrote: if you want electic mirrors you need the electric mirror switch too. I have a spare if you cant get one with your mirrors
Thanks Matt, but luckily, I already have electric mirrors and central locking. It's just the gucci windows I'm missing!
CaptiV8ted
Postby trigger » Wed Jul 29, 2009 11:27 am
Your best bet would be to go to a breakers or find someone who is breaking a Transit with full electrics in the doors and remove the complete loom from the doors, Tourneo GLX ones can also be used, then just remove your loom and replace it with the one from the scrappy, the good thing is that you have the main loom in the van which would be the hardest part to fit if it wasn't already there.
trigger
Postby Wildy » Thu Jul 30, 2009 10:50 pm
I have motors and door looms if your still looking?
Wildy
Users browsing this forum: Bush Mechanic
