51plate 2.5 engine swap with a 2.5 6 cylinder bmw engine ?
Postby knighty1981 » Wed Aug 05, 2009 12:49 am
hi (I'm new!)
I bought a 51plate lwb 90ps 350 single wheeler transit about a year back (for work) was running great... (once I changed the egr valve that is!)
spent quit a bit of time/money on it....
waxol'd and undersealed it all, boarded out with inch ply (floor, wheel arches, bulkhead and walls) then had it fiberglassed so it's waterproof (easy to clean too) then new clutch too....
and now.... the engine is on it's way out.... (just over 100k on it) and I'm pretty miffed to say the least.... have done plenty of engine sways on the mk5 transits, could do one with my eye's closed now... so I'm totally happy about doing a mk6 one (extra electrics, but I'm good with them).... the problem is all the engines I can find are so bloody expensive...
there's tonnes of back pressure, and it's using almost a gallon of oil a week... :(
seeing the prices of a 2nd hand engine.... I thought about sticking an old di in it.... might be easier... but a bit depressing...
I used to have a 325tds bmw, and I LOVED that engine... I used to do trips from Newcastle to London and back (flat out) all the time and I used to just laugh at me and take it all in it's stride....
so I'm thinking of swapping one into my mk6 transit...
it's a pretty long engine... but apart from that they're pretty simple engines... it has a small ecu but that shouldn't be a problem, off the top of my head they're 143bhp and 275lb/foot of torq ?
anyone have any ideas / input to help me along the way ?
I'll buy a bmw mot failure as a donor car so I'll have plenty of parts etc... custom exhaust etc.. is a given
knighty1981
Re: 51plate 2.5 engine swap with a 2.5 6 cylinder bmw engine ?
Postby madmark » Wed Aug 05, 2009 5:15 am
keep me posted i would like to see this done! :wink:
Postby GBBiker » Wed Aug 05, 2009 8:15 am
I don't think the straight six will fit without modifying the bulkhead :?
GBBiker
Wrong Again!
Postby Luke » Wed Aug 05, 2009 9:45 am
is it a strait 6 :? if it is you might have to sit it back which wont be a problem but measure where the gear stick ends up and if theres an easy way to move it forward :idea:
sounds a great swap and i'd be very interested to see it done 8)
Postby GBBiker » Wed Aug 05, 2009 11:22 am
All of the 3 series have inline bank engines :wink:
GBBiker
Wrong Again!
Postby knighty1981 » Thu Aug 06, 2009 2:48 am
was a bit tired last night when I posted and missed a few bits of info out...
the bmw I had... I sold to a friend... so I'll get him to come over one day and I'll have a good look / measure it all up...
aslo... I run all my other vans on veg oil (done properly, twin tank conversion, heaters etc...)
but.... transits are (apparently) no good on veg oil, and it'll kill the engine/pump pretty quick...
but those old bmw (indirect injection) engines love the stuff... can just shove it in the tank :-)
I'll have a think / measure up and see what I can come up with ;-)
knighty1981
Postby madmark_50484 » Thu Aug 06, 2009 9:38 am
knighty1981 wrote:was a bit tired last night when I posted and missed a few bits of info out...
I wouldnt say transits dislike veg I used to run my old one (mk5 nana engine) sometimes 100% no fancy heaters on anything just put it straight in.
Good luck on your project look forward to see the outcome.
Past
Present
Mk5 96 N Reg Transit Luton
www.busesuk.co.uk
madmark_50484
Postby knighty1981 » Thu Aug 06, 2009 11:00 pm
I ran my mk5 on veg too.... apparently it's just the mk6 that doesen't like it :(
(still mix a bit in, but not much)
knighty1981
Postby knighty1981 » Sun Aug 09, 2009 7:45 pm
well my mate I sold my bmw to dropped by the other day so I had a good look at the engine....
and was pretty confident I could fit it into the transit without too much fuss.....
but then I have another look at the transit and I'm getting a bit worried... it would fit right into a mk5 but the mk6 is a lot tighter.... or maybe it just looks tighter....
think I'll need to get the BMW engine out and side by side with a mk6 engine to see what the size difference really is...
on the up side... dropping the fan off the front of the engine and swapping to a could of electric fans should make a big difference...
knighty1981
Postby Luke » Sun Aug 09, 2009 10:50 pm
have a flick through this thread i fitted a cossy YB into a mk6 it'll give you some idea of the space available as theres a few shots of the engine bay and the engine going in - as you can see it will be tight with 2 more clys i think you'll need to mod the bulkhead :D
viewtopic.php?f=27&t=26031
Postby knighty1981 » Tue Aug 11, 2009 2:13 am
thanks
thats a really nice job you did there....
but I'm pretty sure it would be a dog trying to fit the straight six in there....
helf tempted to get rid of this van and get a mk5 instead !
knighty1981
Postby Luke » Tue Aug 11, 2009 9:49 am
whats the measurement from the front of the engine to the gearstick :?: :D
Postby knighty1981 » Mon Sep 14, 2009 2:20 am
bit of an update...
I've been looking around for a decent donor car... there's quite a few around.... the ones I'm looking at 1995'ish are just about the right age now where the body starts to rot and the prices plummet etc...
but... regarding the post higher up....
would an auto box work ok ?
without really thinking about it... I'd have thought the box would have been designed for the weight of the BMW so gear changes etc.. would be messed up by being fitted to the heavier transit....
tho I guess towing something with the BMW would be just the same....
an auto box definitely would make things easier...
knighty1981
Postby AndyG » Mon Sep 14, 2009 5:54 pm
Auto box will be fine :!:
Some BMWs are quite heavy :wink:
Try and get a 4 speed/overdrive one and not a 3 speed :!:
Also check how complex the electronics are, if any, on your choice :wink:
Will make a 8) 8) conversion :D
Postby Chaz&Saz » Wed Oct 14, 2009 6:02 pm
Any progress on this? We have a 325tds and had it for years fantastic engine, i think it would suit a transit well. Land Rover used it in the 2.5DSE Rangies. so can pull weight.
1972 Built, 1973 Registered, Land Liner V6
1967 Triumph Herald - Bethany
1976 Triumph Dolomite
Chaz&Saz
