What's the Mk6 grey called?
Postby Shamrockez » Fri May 12, 2006 1:36 pm
Hi guys, I don't have a Transit, but bear with me..... I've been wanting to paint my 58 Beetle in a nice grey colour:
So she'll eventually look like this:
Anyway - I was sitting at some traffic lights on my way home for work a couple months ago and a Mk6 (??? I think - one which would be on an 04 plate) went past and it was a lovely grey colour - it was one of those dulux colour matching advert type scenes couple with "I want that one" :lol:
So does anyone know what this colour is called, or have a pic of it?
Many thanks :D
*Lucy*
Shamrockez
Postby madmark » Fri May 12, 2006 1:45 pm
hi ,you have steel blue,or a nice magnum grey, both in metalic! :wink:
Postby Shamrockez » Fri May 12, 2006 1:46 pm
Magnum grey sounds like the likely colour. Does anyone have pics of either of these?
Thank you :D
Shamrockez
Postby madmark » Fri May 12, 2006 1:58 pm
hi mate if you go onto the ford website you should be able to see the colour ,magnum is a fairy dark grey ,if i was to have a mk6 this would be the colour! http://www.ford.co.uk
Postby 100ps_drw_hicube » Fri May 12, 2006 2:00 pm
100ps_drw_hicube
Transit Abuser!!
Postby Shamrockez » Fri May 12, 2006 2:11 pm
Must have been medium steel blue then. Unless it was an early Mk6 and the colour has no been discontinued hence not showing in the colour chart?
Shamrockez
Postby Shamrockez » Fri May 12, 2006 2:13 pm
Just googled magnum grey and it came back with this:
Looks similar to the colour I saw.
Shamrockez
Postby 100ps_drw_hicube » Fri May 12, 2006 2:20 pm
yep foci's were magnum grey i will look at my 00 mk6 brochure for you it might say in there :? :D
100ps_drw_hicube
Transit Abuser!!
Postby Shamrockez » Fri May 12, 2006 2:23 pm
If you could, that would be very useful.
Cheers guys :D
Shamrockez
Postby 100ps_drw_hicube » Fri May 12, 2006 2:27 pm
nope yr 2000 mk6's never had magnum grey neither :?
100ps_drw_hicube
Transit Abuser!!
Postby Shamrockez » Fri May 12, 2006 2:31 pm
google shows this as medium steel blue:
Which looks too blue to be the grey I saw.
It was on a mini bus if that makes a difference?
Shamrockez
Postby Shamrockez » Fri May 12, 2006 2:34 pm
A-ha!!! this is it:
Which one is that?
Shamrockez
Postby Shamrockez » Fri May 12, 2006 2:35 pm
why doesn't that work?
Shamrockez
Postby Shamrockez » Fri May 12, 2006 2:38 pm
that's better
Shamrockez
Postby 100ps_drw_hicube » Fri May 12, 2006 3:25 pm
maybe the one you saw was painted after it left the factory :? :? :lol:
100ps_drw_hicube
Transit Abuser!!
