Epic to Bosch pump change - now engine noisier?
Postby oldhenry » Sun May 14, 2006 9:41 pm
Er... When were Epics fitted?, are they still to cuurent 125s?
Believe nothing you hear and only half you see
oldhenry
Postby 100ps_drw_hicube » Sun May 14, 2006 9:58 pm
nope mk4's and mk5's 92-00
100ps_drw_hicube
Transit Abuser!!
Postby AndyG » Sun May 14, 2006 10:24 pm
tim wrote:The Bosch pump timing has to be advanced its not the same as the epic.5mm on the plunger does the job,if you want it in old money set up as epic and advance the pulley as far as it will go that should do.When i do a conversion i move up a notch on the timing belt so i have lots of travel to get it right .It should not be noisier than an epic ,but then again epics can be very noisy too.White smoke on startup is very common but have never seen it using blue injectors.Its more than likely your timing is out so without test equipment its trial and error mate,but one things for sure the epic system is disaster,its just a hole in the ground that you throw money in to
Please be patient with me Tim.
Set the timing as per official.(pegs in all the holes).
Then remove peg in pump pulley.
Then slacken the bolts that hold pulley to pump.
Turn the bolts (in relation to the pulley which remains static)anti-clockwise till they either stop in the elongnated slots or 5mm.
Is this right :?:
Postby tim » Sun May 14, 2006 11:09 pm
Thats it mate you got it in one.The 5mm on the plunger relates to the use of test equipment.You will have to fiddle around for a while until you get it right,but leave the viscous fan and the timing cover off until you have it right,Have you adjusted the mid range fuelling,i get best results at 10%
A WORK OF ART IS A JOY FOREVER
tim
Postby Ecosse » Tue May 16, 2006 7:55 pm
Now running quieter and much less smoke when cold, it just puffs a touch of black smoke on startup, a couple of seconds and its gone :D
Alex
Oh yeh, nearly forgot, the solution was to advance the pump pulley as far as it would go on the slots from the "proper" timing position, as per Tim's instructions 8)
So thanks everyone for the assistance
Ecosse
Postby tim » Tue May 16, 2006 10:08 pm
Good on yer mate,now all you need is 30ml of acetone to 70lt of diesel,and the world is yer oyster
tim
Postby Ecosse » Wed May 17, 2006 8:55 am
:lol: ...you must be a mind reader, it's first dose of acetone went in last night :D
Ecosse
Postby tim » Wed May 17, 2006 9:03 am
Ecosse wrote::lol: ...you must be a mind reader, it's first dose of acetone went in last night :D
Just what she needs mate,a little treat, after years of hardship married to an epic
tim
Postby AndyG » Wed May 17, 2006 10:06 am
:lol: :lol: :lol: :lol: :lol:
Postby stevew » Thu May 18, 2006 10:54 pm
How much did this conversion cost you?
Steve
stevew
Postby AndyG » Thu May 18, 2006 10:56 pm
stevew wrote:How much did this conversion cost you?
Steve
Are you also defecting to Bosch then stevew :?:
Postby stevew » Thu May 18, 2006 11:00 pm
It's pretty tempting. :wink:
From the sounds of things it's only a matter of time untill my Epic gives trouble.
Of course I could just go for a nice V8 instead... :twisted:
Steve
stevew
Postby AndyG » Thu May 18, 2006 11:05 pm
No reply from ecosse :(
Probably depends on where you get the pump from, as this part has to be the bit that costs :?:
Postby Ecosse » Fri May 19, 2006 9:08 pm
Sorry been buried in work :cry:
The pump cost me £120 off ebay, just reconditioned (with guarantee before anyone thinks I am mad :shock: )
The throttle pedal with cable, was a fiver from the local scrappy and I got a new belt for 2 quid (yeh ebay again!)
The work cost me some bleeding knuckles and a flat battery before finding this forum, joining, doing a timing advance, adding some acetone and developing a big smile :D
I've now used 2 tankfulls of fuel since the conversion and am getting approx 60 miles more per tank than I was with the epic and little if any performance difference.
I reckon the conversion will have paid for itself in a few months and I still have the EPIC, pedal and ECU to sell :wink:
Hows that then :?:
Alex
Ecosse
Postby stevew » Sat May 20, 2006 1:51 pm
Ecosse wrote:I've now used 2 tankfulls of fuel since the conversion and am getting approx 60 miles more per tank than I was with the epic and little if any performance difference
Really? :shock:
So what sort of mpg are you getting now?
I'm getting between 300 and 400 miles to a tank depending if it's all round town or all motorway.
Steve
stevew
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot]
