Leaf Spring bolts
Leaf Spring bolts
Postby Aztran » Wed May 17, 2006 10:44 am
The above pics are of two u shapeed brackets inthe middle of the leaf spring.
They are both loose, and the other side is solid!
Should these be tightened?
ive noticed a noise when i go up curbs and i reckon this is it?
2000 x, new style Transit 350!
Aztran
Postby softlad1971 » Wed May 17, 2006 10:57 am
They should be. But when you try they will probably snap. Best to get some new ones.
softlad1971
Postby Aztran » Wed May 17, 2006 10:59 am
Is that a ford dealer jobby or auto part shop?
Aztran
Postby softlad1971 » Wed May 17, 2006 11:00 am
I got my last ones from a breakers that only deal in transits. They were new mind. £10 for the pair.
softlad1971
Postby Aztran » Wed May 17, 2006 11:11 am
ok cool, is there a part name for em.........surely not called 'those u shaped retainin bolt thingies' :lol:
Aztran
Postby softlad1971 » Wed May 17, 2006 11:25 am
I just asked for u bolts that clamp the springs to the rear axle.
softlad1971
Postby gazza » Wed May 17, 2006 1:05 pm
do not but them from a ford dealer, mine came out at a whopping 60 odd quid for bolts and nuts, when you get em off you need o know the length and the width of u bolt for your replacements as there are several sizes,
http://www.jones-springs.co.uk/home.htm this lot do em, very helpful people i have had a spring from em with no complaints
gazza
Postby Aztran » Wed May 17, 2006 2:32 pm
Brilliant, e-mail sent!
Wanna get this b4 drag racing
Aztran
Postby Gunslinger » Wed May 17, 2006 9:04 pm
i picked up mine from a breakers yard, but £10 for a new pair .... i'll have some of that if there's anymore there !!
as for the nuts, i went to my local engineering fastenings place and got some new nuts (nylocks) for a couple of quid, these do have a tendency to either come undone or stretch making them lose, thats why i got nylocks, best to keep an eye on them for a couple of months after you have fitted them, also make sure they have seated firmly in the saddle plate on top of the springs.
Gunslinger
Postby AndyG » Wed May 17, 2006 9:21 pm
Can Aztran not flood the studs with penetrating oil first then try and do them up :?:
I've had to take my nearside leaf out today and boy they were so tight all the way :!: :!: :o
Postby Luke » Wed May 17, 2006 9:24 pm
Andyg wrote:Can Aztran not flood the studs with penetrating oil first then try and do them up :?:
yes :!: but the problem may be that as they are loose the most likely reason is that the shackle has stretched and therefore weakened! - best to get new ones really!! considering the consiqueses of it snapping completly!!! :shock:
Postby AndyG » Wed May 17, 2006 9:26 pm
Should I be fitting new ones on as well :?:
Postby Luke » Wed May 17, 2006 9:28 pm
Andyg wrote:Should I be fitting new ones on as well :?:
had yours come loose :?:
Postby AndyG » Wed May 17, 2006 9:31 pm
NO WAY :!: They were so tight it took me all day to get them off :shock:
I think Ford modified the late ones so they could be left out of the first service :roll:
Postby Luke » Wed May 17, 2006 9:35 pm
Andyg wrote:NO WAY :!:
yours should be ok then :!: no need to replace :D
