Good to hear that it worked as intended - I ordered twin batteries on the new Mk7 mostly because I was concerned about the amount of stuff that's on all the time whether you like it or not, draining the battery while it's parked. It might save me from myself too, as in your case.Daveyboy wrote:What a good idea the second battery is to forgetful old farts like me
Can you explain in more detail why that would be?winterheating wrote:are you going to take the flat battery off and charge it proparly, cos it will never be fully charged if you just let the alt do it.
Would a good, long run (or several long runs, eventually) not do the trick? Those batteries are rather inaccessible under the seat! Could you trickle charge the second battery 'in reverse' by connecting a charger to the 'cigar lighter' socket while the van is parked? I have a solar panel that is supposed to work that way.winterheating wrote:it will never be at full capacity till its trickle charged correctly.
tyman wrote:Can i ask how you have a 2nd battery fitted as would like to fit extra lights in rear on my 05. Is it just a case of linking neg. & pos together? cheers
Vee4 wrote:Would a good, long run (or several long runs, eventually) not do the trick? Those batteries are rather inaccessible under the seat! Could you trickle charge the second battery 'in reverse' by connecting a charger to the 'cigar lighter' socket while the van is parked? I have a solar panel that is supposed to work that way.winterheating wrote:it will never be at full capacity till its trickle charged correctly.
See Jezclayton's post for the kosher way to do it on a Mk7:tyman wrote:Can i ask how you have a 2nd battery fitted as would like to fit extra lights in rear on my 05. Is it just a case of linking neg. & pos together? cheers
It's an option on 260, 280 and 300 FWD models. If you order the rear auxiliary power point (sounds grand but is in reality a cigar lighter socket in the right rear door pillar), the second battery is added automatically.Daveyboy wrote:I thought the second battery was fitted as standard to all mk7's, don't think mine was specifically ordered with it if not
Users browsing this forum: Google Adsense [Bot], nox_46
