no go!!
no go!!
Postby a13z » Wed Dec 23, 2009 12:47 pm
hi. just went out to start my 1999 transit. and there no go. it turns over its a brand new battery. ive tryed jump starting it. any ideas thanks
a13z
Re: no go!!
Postby madmark_50484 » Wed Dec 23, 2009 12:56 pm
Need more info how did it go wrong eg just went out to it one day and wouldn't start or did it die somewhere ?
try bleeding the injectors (17mm spanner) see if fuel comes out and then report back
Past
Present
Mk5 96 N Reg Transit Luton
www.busesuk.co.uk
madmark_50484
Re: no go!!
Postby MrMPuk » Wed Dec 23, 2009 2:15 pm
Assuming it's diesel of course.
Re: no go!!
Postby madmark_50484 » Wed Dec 23, 2009 3:25 pm
Your right mrmpuk so I just did a search of his posts and would suggest he has it also suggests this isn't the first problem he has had.
Past
Present
www.busesuk.co.uk
madmark_50484
Re: no go!!
Postby hifly » Wed Dec 23, 2009 5:34 pm
run out of fuel?, fuel filter dropped off?, stop solinoid not working?, try cracking an injector and turn it over and see if any fuel comes out. What pump is it?, have you been running on veg oil?
this lot will do for a start.
hifly
Re: no go!!
Postby a13z » Wed Dec 23, 2009 6:04 pm
rght. hasnt been started for a few days now. but the turn over is very quick and there is fuel in the injectors. and the starter motor not that old
a13z
Re: no go!!
Postby dpsservices » Thu Dec 24, 2009 1:17 am
me personally would tow it
iveco daily xlwb 35s12
dpsservices
Re: no go!!
Postby Altransit » Thu Dec 24, 2009 1:48 am
Is it turning over faster than normal?
Re: no go!!
Postby GBBiker » Mon Dec 28, 2009 1:54 pm
madmark_50484 wrote:Need more info how did it go wrong eg just went out to it one day and wouldn't start or did it die somewhere ?
My injectors are 16mm :?
GBBiker
Wrong Again!
