Clunking Clutch 3/4th gear only
Postby Trojan » Sun Dec 27, 2009 7:49 pm
Any advice for me? I have a 1993 LWB Mk4 2.5D Transit, which has driven fine until today. I was coming down towards a roundabout off the motorway, geared down to 4th, no problem. When I slowed yet more, the clutch pedal made a "crack" sound, but did disengage. Seemed fine, but when I got back into 4th, it did the same thing. A few roundabouts later, I got the same in 3rd gear as well. It's fine in lower gears, as well as in 5th.
I have not had chance to look at anything, so it could be absolutely simple, but wondered if anyone has come across this before, and have any suggestions on what could be wrong - what I could look at?
TIA.
Some people say I am stupid... I never realised I was that clever.
Trojan
Re: Clunking Clutch 3/4th gear only
Postby ake » Sun Dec 27, 2009 9:35 pm
sounds like your automatic adjuster at the top of the clutch pedal is failing
Postby Trojan » Sun Dec 27, 2009 10:02 pm
Is that an easy fix, or something that the garage needs to do? Is there anything I can do to "nuture" it?
Trojan
Postby Trojan » Tue Dec 29, 2009 12:45 pm
Sorry to blatently bump this - just wondered if anyone knew a fix, or bodge? Cheers.
Trojan
Postby GBBiker » Tue Dec 29, 2009 1:00 pm
New clutch cable :wink:
GBBiker
Wrong Again!
Postby bortaf » Tue Dec 29, 2009 9:52 pm
If its the clutch adjuster changing the cable wont help, change the clutch adjuster :wink:
They are about a tenna, a pain but not overly technichal to do, they loose teeth and slip then the slipping chips more teeth and eventualy the pedal just hits the floor with out pulling the cable enough to get a clean gearchange.
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby manandvan » Wed Dec 30, 2009 4:38 am
i just posted the solution for this problem go to clutch topic ive put it there for all to see, it cost 2pence to fix!! :D
manandvan
Postby manandvan » Wed Dec 30, 2009 4:43 am
p.s. posted it amongst a topic called clutch adjustment started by minormatt. maybe someone could move it to where it belongs and add some photos to it??
manandvan
Postby Trojan » Wed Dec 30, 2009 12:58 pm
manandvan wrote:p.s. posted it amongst a topic called clutch adjustment started by minormatt. maybe someone could move it to where it belongs and add some photos to it??
Thanks - found it, and will have a go at that later.
Trojan
