hateful Transit fan belt
Postby gemma08 » Wed Dec 30, 2009 10:02 pm
A few weeks ago i posted about my squeaking fan belt.The saga continues.
I have now changed the belt (again) a ford item. The top idler bearing and the tensioner unit. There isnt any slack in any of the other components or any sign of excess wear on the pulleys and yet it still squeaks. aaarg.
If i slacken the tensioner (using peg hole) a hair with engine running (yeah, i know) the squeak goes away so it seems to me the belt is too tight. Noise is defo from flat side of belt as a touch of flour on it causes noise to go for a second or two. Nothing else has been touched.
HELP
may the fleas of a thousand camels infest your armpits
gemma08
Re: hateful Transit fan belt
Postby winterheating » Thu Dec 31, 2009 1:20 pm
gemma08 wrote:A few weeks ago i posted about my squeaking fan belt.The saga continues.
HELP
are some not ford parts :?:
winterheating
Postby gemma08 » Thu Dec 31, 2009 1:43 pm
Findings today are, If i move the tensioner a bit further with engine running the belt moves over the pulley by about 6mm indicating something is out of line also top of the new (ford) belt is very shiney. So i removed the tensioner pulley and found the bearing not seated correctly, i fiited a new bearing to the original ford pulley and refitted and the squeak is still there but belt is now running at the very front edge of the pulley. Bloody imitation parts im off to Ford now for the oe bit. If it cures it noise its been an expensive lesson. The thing is the squeak was there with a ford tensioner.
gemma08
Postby winterheating » Thu Dec 31, 2009 1:47 pm
just spray with wd40 at various places till squeak stops to idebtify the problem.
winterheating
Postby MrMPuk » Thu Dec 31, 2009 1:50 pm
winterheating wrote:just spray with wd40 at various places till squeak stops to idebtify the problem.
Good way to wreck a new belt.
Postby winterheating » Thu Dec 31, 2009 1:54 pm
just a little squirt needed, i'm sure it would dry up and not cause a problem if any did get on the belt:?:
winterheating
Postby MrMPuk » Thu Dec 31, 2009 1:57 pm
I thought it was just another comment like the filling oil through the dipstick hole.
Postby winterheating » Thu Dec 31, 2009 1:59 pm
:lol:
winterheating
Postby gemma08 » Thu Dec 31, 2009 5:44 pm
OK, now the latest and final chapter.Closer inspection found the tensioner forcing the belt out of line, dont know how i missed it before tbh. Went off to Ford and £120 lighter got a OE tensioner. I compared and measured both tensioners and can see little difference. Fitted OE and squeak has gone and belt is running in line. But we`ll see what happens when paint has worn off the new pulley.
The other thing i did notice is the ford OE part doesnt make belt as tight a the pattern part did.
gemma08
Postby ake » Thu Dec 31, 2009 5:57 pm
I think you have just had a lesson in why not to use cheap pattern parts :)
Postby ihaveagsxr » Fri Jan 01, 2010 2:45 pm
ake wrote:I think you have just had a lesson in why not to use cheap pattern parts :)
i used the ford tensioner with a new bearing, i machined it down in the lathe to the right size and it seems to work fine, cos me about 16 - 20 euro cant remember exactly
ihaveagsxr
