transitjon wrote:hi is it possible to override the thermal cut out on the unit as mine will only run for about 10 seconds unless i keep the reset switch pressed in
thanks
jon
Jim Archer wrote:It's cos it's either the thermocouple gone, not catching properly due to fuel supply problems, or no water in it.
HTH
Jim
psv-hgv-flt wrote:transitjon wrote:hi is it possible to override the thermal cut out on the unit as mine will only run for about 10 seconds unless i keep the reset switch pressed in
thanks
jon
that is not a good idea and is not solving the problem. sounds like it could be flame out sensor or lack of air intake.?? try looking hear.![]()
http://eberspacher.com/downloads/techni ... manual.pdf
http://eberspacher.com/support-and-down ... ments.html
ake wrote:Check that the air intake isn't iced(snowed) up
transitjon wrote:ake wrote:Check that the air intake isn't iced(snowed) up
air intake clear , when i turn on the unit it only stays on for 5 seconds and then cuts out what is the first thing to check
thanks
psv-hgv-flt wrote:transitjon wrote:ake wrote:Check that the air intake isn't iced(snowed) up
thanks
it takes more than 5sec for glowplug to fire her up. take plug out again and test out.
psv-hgv-flt wrote:whirrs could be water pump motor, pull pipe off and see if free. (by hand) ps what year is she and are we talking about hydronic..???
Users browsing this forum: Altransit
