Major electrical fault on 55 Plate
Re: Major electrical fault on 55 Plate
Postby andyt1 » Mon Jan 04, 2010 2:53 pm
could this be the culprit? as far as know though the van has never had a towbar we have had it from new.
andyt1
Postby andyt1 » Mon Jan 04, 2010 3:43 pm
Hi guys
Important update found that the ABS fuse has blown in the engine bay fuse box :D
Just going to try and change it with another could this be the problem Lets hope so.
Just had a look at the owners guid it says ONLY TO BE REPLACED BY AN EXPERT Can some one please inform me as to why, and if i can change it with fuse 102 as i dont have a heated windscreen.
andyt1
Postby andyt1 » Mon Jan 04, 2010 4:05 pm
OK changed the fuse but still the same ABS Light on plus Traction control not going off.Still no lights :(
andyt1
Postby ireland.1495 » Mon Jan 04, 2010 9:41 pm
andyt1 wrote:Yeaph the van is half ply plus shelves all round so it will be a night mare trying to trace every wire :cry:
r you sure non ot nails - screws have not gon - nicked any wires
get your self a multi meter & 6 pk and have some fun :D
cheque any ad on first by ford or any body
remember these r not part of loom and some times fail
ireland.1495
Postby winterheating » Mon Jan 04, 2010 10:33 pm
if the the fuse has gone then check everything that could have blown it, like wheel sensors, and check the ABS pump multiplug for corrosion.
winterheating
Postby andyt1 » Tue Jan 05, 2010 1:11 am
the wierd thing is that when i replaced the fuse (after careful consideration ie ONLY AN EPERT SHOULD REPLACE) the bloody thing didnt blow, but the lights still dont work :( . I thought that if i had missed this obvious thing (a blown fuse) that maybe just maybe my lights would work. No wonder that auto spark negg got charged him £180 (ive looked at all posts regarding wireing).At this moment in time i would pay trebble that to get her going.
So far i have had 2 days worth of frost bite and iam still going to have to fork out for a sparky.
When and if i get this fault sorted i will post the answer.I think i have checked everything that is posible to check so guys thanks for all the help and thanks ireland for the tip Multi meter & Tinnys.
andyt1
Postby AndyG » Tue Jan 05, 2010 1:15 am
Andyg wrote: start disconnecting various parts of the loom :!:
At least try and isolate where the trouble is :!: (just a matter of blowing a few more fuses :idea:
So are the lights fuses still blowing :?:
Postby ake » Tue Jan 05, 2010 7:34 am
I am thinkin that the loom is screwed in the back of the van
Postby ireland.1495 » Tue Jan 05, 2010 10:11 am
i think myself this could b the prob
i mean just may b some wire got nicked - pined hear it sounds the best place to start
happen to me in an old escort put nice racking in before i sold her she was fine 4 a mounth then i
had a guy intrested in her he came to do the deal and as luck would have it
she played up light did not work ect :evil:
turned out to b a nail nick a wire in the back :oops:
o the fun i had
ireland.1495
Postby andyt1 » Tue Jan 05, 2010 7:55 pm
:D :D :D Got it sorted :D :) :D
Fault was chaffing of the wire Undereath the expansion tank Front N/S :D
This was the only part that i didnt check.
Thanks a million for all the help guys
andyt1
Postby winterheating » Tue Jan 05, 2010 7:59 pm
andyt1 wrote::D :D :D Got it sorted :D :) :D
was it going to abs pump :?: or small relay box underneath expansion bottle :?:
winterheating
Postby negg » Thu Jan 07, 2010 12:02 am
GLAD YOU GOT IT SORTED !!! BUT HEY I DID ASK YOU TO CHECK THIS !!!!! I THINK IN THE FIRST REPLY TO YOU FRONT N/S BEHIND HEADLIGHT ! I HAD THE SAME PROB PLEASE LISTEN MATE LOL SAVE YOU ALOT OF TIME AND I GUESS MONEY THANKS NEIL
negg
Postby chrisadam » Thu Jan 07, 2010 12:46 am
just a thought mate, easy way to try to narrow things down try disconnecting all lights and replacing fuse. if doesnt blow try plugging in one by one till blows then if you do find one blows you got better idea where to look.
chrisadam
Postby chrisadam » Thu Jan 07, 2010 12:47 am
or try same with switch aswel
chrisadam
