Banana Push Rods..!!
Re: Banana Push Rods..!!
Postby AndyG » Sat Jan 16, 2010 12:07 am
ake wrote:Have you ever actually known a Di bend a valve Andy :?: I don't think I have, but some unlucky lad somewhere will have :(
That's the one :!: :shock:
Always one :wink:
Postby psv-hgv-flt » Sat Jan 16, 2010 10:59 am
jay wrote:wanna bet about valve damage!!
This is the result of someone in my very old white swb that was doing 70mph and the belt snapped and then they tried tow starting it around the block...valve bits embeded in the pistons and head...But my old black beasty van was bought with a snapped belt and that ran ok after doing just the belt and straightning the push rods in a vice...I have also done the same to another transit at the side of the road as well..
:shock: nice mess that, never had one do more than bent push rods and crack the rocker arms.
psv-hgv-flt
Postby V184 » Sat Jan 16, 2010 11:10 am
Perhaps the valve failed causing the belt to snap ?
V184
Postby psv-hgv-flt » Sat Jan 16, 2010 11:14 am
poss, :?:
psv-hgv-flt
Postby wilks » Sat Jan 16, 2010 2:16 pm
Andyg wrote::evil:
Well, if you did a bit of searching on here first, you'd know that you wouldn't have to remove the head :!:
I'm not sure if it's too late at this stage to simply put back the bolts back you've already removed :| That's up to you :!:
I'd have removed the rocker assembly, pin locked the engine, then drop in the new push rods, fit the rocker assy back on and continued to fit the cam belt and tensioner :)
Lastly check all the tappet clearances and you're virtually home :D
I have the same problem with my pushrods,I have taken off rocker after cambelt broke and push rods all bent,I don't think there was any further damage as I was only going slow round a roundabout at the time.
I have been told that after fitting the New cam belt which I have done and then to place in the new push rods but to set the tappets I have to: to put the pin back in the crankshaft,I know where the pin is for the crankshaft and at the same time to get the /piston/pistons to TDC.I have seen the previous posting sent to me but means knothing to my understanding.
Can anyone explain further.
regards
Wilks
wilks
Postby wilks » Sat Jan 16, 2010 2:40 pm
Hi All.
After fitting new Cam belt that snapped and then finding the pushrods on my Transit 1996 have bent,now I am upto the stage after fitting new belt and have placed in the new rods how do you set the tappets as someone has mentioned about the piston/pistons being at TDC at the same time as fitting the pin again on the crankshaft before setting up tappets.As the last guy said I don't want to go to all this effort and it goes bang again.
Also I think my van has had the same water pump since new as its never been changed since I have owned it myself in 12 yrs,It hasn't caused me a problem but do you think I should take the cover off again and fit a new one while doing this job..if so is it a straight out and in job?
Can anyone advance on the order of setting up to finish job and explain what I need to do ref the setting of Tappets and the TDC thing. :(
regards
Wilks
wilks
Postby eurorep » Sat Jan 16, 2010 3:20 pm
Hello Wilks,,I bought a HAYNES MANUAL before anything happened to me. OK, the belt snapped and the rods got kettled but as most of the guys on here say..its unlikely that any valves have been damaged. I just finished taking the head off to make sure mine were not knackered....all ok. Also it gave me a chance to have a major clean up. Once the new head gasket set and push rods arrive all should be tickety boo.! As for correct timing that seems straight forward enough with the correct pins in place locking the pump, crank and camshaft.
I,m sure theres plenty of bodies on here that will also reply..best of luck.!
eurorep
Postby AndyG » Sat Jan 16, 2010 4:12 pm
Postby eurorep » Sat Jan 16, 2010 10:32 pm
Just a quick note to what i, m doing. I took the head off with the inlet manifold half still in place. I was surprised at the amount of crap built up in there. This was the same at the other half so i gave them a good wash out with petrol iusing a bottle scrubber brush, clean rags to dry and they sure look a lot better. I, m wondering if there is a reason for this build up or is this normal to these engines.? Never had a problem with transit in the past so this is a new avenue for me ... but interesting.
eurorep
Postby jay » Sun Jan 17, 2010 9:54 am
yeah thats normal black crusty crud...thats the egr valve for you..
mk1 connect tourneo
jay
Postby ake » Sun Jan 17, 2010 5:00 pm
jay wrote:yeah thats normal black crusty crud...thats the egr valve for you..
Which is why its a good idea to blank off your egr valve
Postby bazw » Sun Jan 17, 2010 5:38 pm
wilks wrote:Hi All.
regards
Wilks
heres how i do it
dont fit rocker shaft ,
peg fly wheel at timing hole so pistons are in right place , set cam wheel to timing mark and pin set pump to timing mark and pin , this is when you should fit belt and then release tensioner and retighten
then fit rocker shaft and seat rockers into pushrods
use procedure in andys post for order to set up rockers
this way theres no way for valves to make contact with pistons
hth
350L Series 56 plate
2.4 duratorq 115 ps
A.R. 4.27
bazw
