MattBlackMinibus - Progress Report
Re: MattBlackMinibus - Mk4 Front Grill photographed at last!
Postby jerry2 » Tue Dec 22, 2009 10:37 pm
Just read the whole thread . Loving the minor detail changes looking a bit special now m8. Keep up the good work.
jerry2
Postby MattBlackMinibus » Thu Dec 24, 2009 3:24 pm
jerry2 wrote:Just read the whole thread . Loving the minor detail changes looking a bit special now m8. Keep up the good work.
Cheers mate :D I'll try :wink:
Starting All Over Again
MattBlackMinibus
Postby smiley face mike » Tue Jan 12, 2010 9:07 pm
was it a big job to fit that bumper mate :?:
smiley face mike
Postby MattBlackMinibus » Tue Jan 12, 2010 9:54 pm
smiley face mike wrote:was it a big job to fit that bumper mate :?:
Not really :D
How I did it:http://fordtransit.org/forum/viewtopic.php?f=13&t=47042
MattBlackMinibus
Postby MattBlackMinibus » Sat Jan 16, 2010 6:33 pm
Went out on Wednesday to pick up a Euro Emergency Breakdown Kit
for a trip to France that night, and my steering felt odd.
Nearing home the van starting to pull to the right :!: Uh-Oh :(
Stopped at home and the drivers side front wheel was shmokin big time.
Smelled like clutch.
Hub was about a thousand degrees cee :shock: Holy sheet :!:
Had some new discs to fit anyway, so set about stripping it all down Thursday.
Top caliper hanger bolt was seized, and the head rounded (one of the 15mm ones).
Gave up till Friday. Had another go. Failed. Gave up again.
Managed to remove it today (Saturday).
Fitted new disc to hub,
filed down the head of the rounded bolt to 14mm,
pushed pistons into caliper to make room for new disc (pistons moved ok)
and re-assembled.
Pads are about 8 weeks old, and bearing is about 10 weeks old.
Hub/disc spun freely, no probs.
Started van pumped brakes.
Just been round the block,
brakes work lovely, but the disc is red hot again :roll:
Any ideas?
MattBlackMinibus
Re: MattBlackMinibus - Overheating brake disc problem :-(
Postby AlanN » Sat Jan 16, 2010 8:13 pm
either wheel bearing too tight
brake binding
time to jack up again and have nose around
Postby MattBlackMinibus » Sat Jan 16, 2010 8:42 pm
AlanN wrote:either wheel bearing too tight
brake binding
The wheel hub didn't heat up on this short journey so not bearing, defo the disc.
I'm gonna strip the caliper in the morning.
Been racking my brain cell (which is now also overheating)
and reckon that despite the fact that I was able to move the pistons in,
they must be sticking a bit.
Sh1te behind the rubbers probably.
MattBlackMinibus
Postby WINDSCREENGUY » Sat Jan 16, 2010 8:48 pm
collapsed flexi hose?
formally grey van man.
WINDSCREENGUY
previously grey van man
Postby AlanN » Sat Jan 16, 2010 8:50 pm
grey van man wrote:collapsed flexi hose?
agreed
Postby MattBlackMinibus » Sat Jan 16, 2010 8:59 pm
Ooh :!:
This is exactly why I posted this up,
to get oddball possible suggestions that I wouldn't have imagined :D
Cheers Steve
MattBlackMinibus
Postby Luke » Sat Jan 16, 2010 9:20 pm
yeah worth a try happened on mine too :idea: doesnt normally happen on cars much but seems to be common on transits mabe due to the bend the flexi goes through with the huge lock they have :? :D
Postby Muttley » Sat Jan 16, 2010 9:20 pm
agreed
Thirded, the flexis can give way internally and act like a one way valve holding the brakes on.
Expert burns receiver.
Bodger Extraordinaire!!
Fallen in love/hate with Mk6s
Muttley
Postby MattBlackMinibus » Sat Jan 16, 2010 10:39 pm
Which, if it is that, will mean I'm totally screwed until I get hold of another one :evil:
MattBlackMinibus
Postby MattBlackMinibus » Sun Jan 17, 2010 12:00 am
are they Ford only?
MattBlackMinibus
Postby AndyG » Sun Jan 17, 2010 12:19 am
