Seperate BT heater
Seperate BT heater
Postby AndyJ2506 » Fri Jan 15, 2010 12:15 pm
Hi guys
My van came with one of the little cab heaters found on the BT vans so could somebody please tell me how these work as my van takes a good 15 miles to warm up and its not fun. i can get it and the fan in the cab to run but it never gets hot. Also my temp gauge doesn't work so would this contribute to it not warming up very quickly
Cheers in advance
Andy
Call 07739463511
AndyJ2506
Re: Seperate BT heater
Postby bertie » Fri Jan 15, 2010 1:45 pm
Sorry I don't know about BT heaters, but I can tell yopu, the temperature gauge will not affect the speed of warming up. However, are you sure the temp gauge i not working, or is it that the thermostat is stuck open or missing. Either of these reasons will slow the warm up, and the gauge will not register much of a temp.
bertie
Postby psv-hgv-flt » Fri Jan 15, 2010 4:44 pm
AndyJ2506 wrote:Hi guys
Cheers in advance
Andy
can you hear the pulse pump clicking, and has the fuel tap been turned off.?? it will be no fuel/ pump /glowpin.
http://eberspacher.com/support-and-down ... ments.html
:wink:
psv-hgv-flt
Postby davev6newman » Fri Jan 15, 2010 8:34 pm
As far as i know these heaters are simular to the eberspacher heater, they run on diesel and work independently from the normal heater. You can even set them to come on early so as to warm the van up before you get in it in the mornings.
How they work i do not know tho.
davev6newman
Postby AndyJ2506 » Fri Jan 15, 2010 10:58 pm
Cheers for the replys guys. The thing seems to be running fine and i can feel the gases coming out of the exhaust. i wonder if the stat not working would affect the temp. Also the temp gauge doesn't register anything. I'll have a bit of time on sun to look at it all so any suggestions as what and where to look would be much appreciated. I know a bit about cars but i've never worked on a transit before so it'll be a whole new learning curve :)
Call 07739463511
AndyJ2506
Postby ake » Sat Jan 16, 2010 11:25 am
davev6newman wrote:As far as i know these heaters are simular to the eberspacher heater, they run on diesel and work independently from the normal heater. You can even set them to come on early so as to warm the van up before you get in it in the mornings.
They are similar to an Eberspacher because they ARE an Eberspacher :wink:
Postby psv-hgv-flt » Sat Jan 16, 2010 11:30 am
:lol: :lol:
psv-hgv-flt
Postby davev6newman » Sun Jan 17, 2010 7:28 pm
Guess thats me told then! :lol:
davev6newman
Postby AndyJ2506 » Sun Jan 17, 2010 10:20 pm
does anyone know how they work then :?:
Call 07739463511
AndyJ2506
Postby MinorMatt » Mon Jan 18, 2010 10:44 am
are you pressing the button and then starting straight up? If so it will do sod all. Switch it on about 15min before starting the engine, it will preheat the coolant to about 80 degrees...
The other thing is to check its still plumbed in - ie its got the water pipes connected
Postby madmark » Mon Jan 18, 2010 3:05 pm
i asume this beeing a old mk5 it wont have the d2 type it must have all the water heating gummings and tanks and god knows what else!
Postby MinorMatt » Mon Jan 18, 2010 3:33 pm
Yup it will be a d5w
Postby AndyJ2506 » Mon Jan 18, 2010 7:14 pm
MinorMatt wrote:are you pressing the button and then starting straight up? If so it will do sod all. Switch it on about 15min before starting the engine, it will preheat the coolant to about 80 degrees...
Cheers for the replys. I'm pretty sure itsstill plumbed in asall the pipes still run into the engine bay. I left it running for about 35 mins and it was still blowing cold air. It seems to be running ok itsjust not getting warm
Does anyone know anybody who servicesthem around Essex area
Call 07739463511
AndyJ2506
Postby Willowbrook » Tue Jan 19, 2010 1:20 am
theres a firm in basildon
Willowbrook
Postby riche100 » Wed Jan 20, 2010 6:16 pm
http://www.dropshots.com/transit120#dat ... 3/12:47:31
thats mine installed by guy88 off this forum .....
i collect old fruit machines , if anyone has any or knows of any from the early 80s to 90s please :)
riche100
