Engine Management Light keeps coming on
Postby exriotvan » Wed Jan 20, 2010 12:40 am
I have a MK5 2000 Transit 2.5 td Epic, whilst driving to birmingham from northampton last week my engine management light came on and i went into limp mode, tried turning of the ignition and turning it back on but the light was still on, carried on driving to destination for another 30 miles, turned ignition off and left for about 20 mins got back in and the light wasn't on.
Drove home fine with no problems, speed back to normal and no light. Went to go to poole today and got about 20 miles from the house and the light came on, completely shut of the engine until i restarted it, went into limp mode, drove for about 25 miles back home, stopped went to go out a little while ago and the light had gone out. I dont know whats wrong with it?
Had a new cambelt changed about 6 months ago, had no problem until now
thanks in advance
exriotvan
Re: Engine Management Light keeps coming on
Postby jay » Wed Jan 20, 2010 8:51 am
you need to get the codes read.
mk1 connect tourneo
jay
Postby exriotvan » Wed Jan 20, 2010 5:25 pm
Hi got the codes read and they are 1172.0335 and 0336.
any ideas welcome
thanks
exriotvan
Postby madmark_50484 » Wed Jan 20, 2010 5:39 pm
Found this online
http://www.giordanobenicchi.it/tecnica% ... Manual.pdf
1172 Pump Rotor Control Overfuelling
0335 Engine Speed Sensor
0336 Engine speed Lost
In that pdf gives a number of things to try worth a look if you ask me
Past
Present
Mk5 96 N Reg Transit Luton
www.busesuk.co.uk
madmark_50484
Postby psv-hgv-flt » Wed Jan 20, 2010 7:39 pm
madmark_50484 wrote:Found this online
check resistance (ome) max and min. :wink:
psv-hgv-flt
Postby exriotvan » Wed Jan 20, 2010 8:24 pm
Hi i noticed on another thread that you have a service technical manual for the epic would you be willing to send me a copy.
thanks
exriotvan
Postby psv-hgv-flt » Wed Jan 20, 2010 8:49 pm
thanks
hear is some of it.
:wink:
psv-hgv-flt
Postby exriotvan » Wed Jan 20, 2010 8:53 pm
hi could you send the whole copy to my email i am having mega problems with the van and really need it.
thanks
exriotvan
Postby psv-hgv-flt » Wed Jan 20, 2010 8:56 pm
psv-hgv-flt
Postby exriotvan » Wed Jan 20, 2010 8:58 pm
psv-hgv-flt wrote:Image
Hi do you have a copy of the whole manual? you said in a different thread to ask if you wanted a copy
thanks
exriotvan
Postby psv-hgv-flt » Wed Jan 20, 2010 9:02 pm
will put on other thread, and will take some time to scan, then put on to photo bucket, then copy and paste to that thread. :shock: :(
psv-hgv-flt
Postby exriotvan » Wed Jan 20, 2010 9:05 pm
Hi if it is easier cant you scan it and print it off? i dont mind paying for the paper and postage.
thanks
exriotvan
Postby psv-hgv-flt » Wed Jan 20, 2010 9:08 pm
no, there is a lot to scan and then all can look an print.
psv-hgv-flt
Postby exriotvan » Wed Jan 20, 2010 9:09 pm
ok thanks
exriotvan
