how to bypass a mk7 egr valve?
Postby Luke » Sat Jan 30, 2010 3:45 pm
not sure if this is either true or allready on the forum but i cant find any info :!:
but apparantly you can bypass the mk7 egr by removing a gear out of it so it stays shut but doesnt throw up the engine managment light :!:
anyone tried it :?: does it work :? :D
Re: how to bypass a mk7 egr valve?
Postby Mike » Sat Jan 30, 2010 3:52 pm
Luke wrote:not sure if this is either true or allready on the forum but i cant find any info :!:
I did try it but the EML was already on, it didn't clear the EML. Coconut suggested that it may work though. But others have said that the MK7 EGR has a position sensor in it. Give it a go.
Mike
Wind up merchant!
Postby ake » Sat Jan 30, 2010 4:26 pm
If you blank it it puts the light on, and if you unplug it it puts the light on, so i'm guessing if you take a gear out of it it will put the light on :(
I've just had a new one, I should have kept the old one and I could have tried takin it to bits :oops:
Postby Victer van man » Sat Jan 30, 2010 6:05 pm
I blanked mine off about 6000 mile ago, management light came on but I just ignored it as the van was running perfect.
Strangely though over the last couple of weeks the engine malfunction message has appeared on my
screen and the van goes into limp mode. Once I turn the engine off and restart it runs fine for sometimes a couple of days before it comes on again.
The last time it came on, I turned the engine off and unplugged the EGR while it was whistling and the noise stopped. Restarted and the van was as flat as a dab. Stopped again waited for the EGR to stop whistling unplugged it again and the van ran fine.
The only thing I can think of was the first time I unplugged the EGR it was partly open and had sent a signal to the brain. causing loss of power.
When I unplugged the second time the EGR was closed so no signal was sent to the brain.Either way the engine malfunction message hasn't appeared on the screen since.
[b]Jumbo driver's go the distance[/b
Victer van man
Postby Luke » Sat Jan 30, 2010 6:41 pm
ake wrote:If you blank it it puts the light on, and if you unplug it it puts the light on, so i'm guessing if you take a gear out of it it will put the light on :(
this info's come from a ford mechanic and it's supposed to not put the light on :D but i dont know how true it was as i didnt speak to him myself :)
Postby ake » Sat Jan 30, 2010 7:13 pm
I may be wrong but I thought it had some kind of flow sensor inside it which is why the light comes on if you blank it
Postby Mike » Sat Jan 30, 2010 7:33 pm
Mike
Wind up merchant!
Postby belly » Sat Jan 30, 2010 7:45 pm
Even your Egr looks cleanish Mike :lol: I'm quite surprised considering the trouble these things cause no one has designed a blanking kit that also adapts the signals for the ecu yet! :)
belly
Kaiser Chief
Postby Mike » Sat Jan 30, 2010 7:47 pm
belly wrote:Even your Egr looks cleanish Mike :lol: I'm quite surprised considering the trouble these things cause no one has designed a blanking kit that also adapts the signals for the ecu yet! :)
LOL, that was the 25k mile one that started playing up.
Mike
Wind up merchant!
Postby Luke » Sat Jan 30, 2010 8:46 pm
nice pic mike :D i think its the middle gear he removed :D
Postby Mike » Sat Jan 30, 2010 8:50 pm
Luke wrote:nice pic mike :D i think its the middle gear he removed :D
That's the one on the blue paper.
Mike
Wind up merchant!
Postby Tdci_boy » Wed Feb 03, 2010 5:03 pm
So now you have 1 apart, what was the fault, is it something the precision engineering company I use can have a look at & repair & maybe we could set up some kind of exchange scheme going :D
Transit Custom Limited H1 L2 DCIV, now converted to van by removing the seats etc so now twin side loading doors, fully kitted out with Sortimo racking, always loaded to capacity & averages 35mpg :D
Tdci_boy
GLX Posse
Postby Mike » Wed Feb 03, 2010 5:11 pm
Tdci_boy wrote:So now you have 1 apart, what was the fault, is it something the precision engineering company I use can have a look at & repair & maybe we could set up some kind of exchange scheme going :D
No idea fella, Ford put a new one on for me.
Mike
Wind up merchant!
Postby Tdci_boy » Thu Feb 04, 2010 2:04 am
Do you still have the unit or did they keep it
Tdci_boy
GLX Posse
Postby Mike » Thu Feb 04, 2010 8:10 am
Tdci_boy wrote:Do you still have the unit or did they keep it
No they kept it as it's a warranty job.
Mike
Wind up merchant!
