Mondeo Clocks in a MK 3
Postby Guy88 » Fri Jun 16, 2006 10:54 pm
Fitted the mondeo clocks today. all the lights are working. just need to fit the speedo cabel and run rev counter wire
This is what i had as of about five mins ago 8) 8) 8)
Thanks to Bryan for the wiring info.
Will get a pic tomorow when its done. Hopefully :roll:
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Luke » Fri Jun 16, 2006 11:00 pm
hold on...................... mk3????? i thought these would only fit mk5 :?
Postby Guy88 » Fri Jun 16, 2006 11:06 pm
They fit the MK5 Plug 1st time But they will fit anything. if wired correctly :roll: .
What you cant see is that i have took the MK 3 plug off and fitted the two mondeo plugs in its place.
Correct wiring here http://fordtransit.org/forum/viewtopic.php?t=6651
Once you know which ones which its easy.
Il get a pic tomorrow and possibly do a how to unless Bryan does one 1st 8)
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby 100ps_drw_hicube » Fri Jun 16, 2006 11:08 pm
guy aint yours petrol?? :? if so try the 8000rpm clocks :D :idea: :roll:
100ps_drw_hicube
Transit Abuser!!
Postby Guy88 » Fri Jun 16, 2006 11:12 pm
Yes mines Petrol.
I had a set out of a petrol mondeyo but when i tried them there was a small amount of smoke and they now dont work :oops: :oops: :oops: Anyway the Pinto is rated to 5500 rpm contant so there near enough
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Luke » Fri Jun 16, 2006 11:12 pm
the wiring doesnt worry me too much, but i always thought they were a different shape to the mk3 are they a perfect fit -cosmetically :? :lol:
Postby Guy88 » Fri Jun 16, 2006 11:13 pm
Luke wrote:the wiring doesnt worry me too much, but i always thought they were a different shape to the mk3 are they a perfect fit -cosmetically :? :lol:
Depends weather its for show or not :lol: :lol:
Il figure something out if it dont match :lol:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Luke » Fri Jun 16, 2006 11:16 pm
Guy88 wrote:Depends weather its for show or not :lol: :lol:
get us some pics in the daylight then bud!! :lol:
Postby pce-hq13 » Sat Jun 17, 2006 10:49 am
Looks cool, wouldn't mind doing the same to my MK4
pce-hq13
Postby Guy88 » Sat Jun 17, 2006 11:37 am
I will do a how to when its done :D
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Guy88 » Sat Jun 17, 2006 2:11 pm
This is what iv got now 8) 8) 8)
Not boxed in as a combination of it being too hot and attempting to solder my fingers made me want a break and start the how to. More later :D
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Luke » Sat Jun 17, 2006 2:15 pm
ah right so will the front cowl need modifying to fit :?:
and this may seem a lame question but do they have a clock on them :?: :lol:
Postby Guy88 » Sat Jun 17, 2006 3:43 pm
It will need modifying depending on how you mount the clocks. it will fit but the clocks will need to be a long way and facing upwards.
No theres no clock you get a rev counter instead :lol: :lol:
How to is now up 8)
http://www.fordtransit.org/forum/viewtopic.php?t=6665
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby 100ps_drw_hicube » Sat Jun 17, 2006 3:51 pm
but you could quite easily fix a fez mk3 clock where the gear numbers are on the dash :idea: :D :D
100ps_drw_hicube
Transit Abuser!!
Postby Guy88 » Sat Jun 17, 2006 4:11 pm
Do what i did and buy a watch :lol: :lol: :lol:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
