non starter
non starter
Postby dav3pops » Wed Feb 10, 2010 11:20 pm
hi all i gotta v reg 2.5 tranny which is a great starter all the time the temp is above zero.....soon as it drops below it doesnt wanna know ...1st time it ran the battery down i changed it ...but since it has been a non starter every time we have sub zero temp.....no glow plug light on the dash....but read somewhere it may not have glow plug...please advise ta
dav3pops
Re: non starter
Postby MinorMatt » Thu Feb 11, 2010 10:30 am
sounds daft - but when was the oil last changed and what grade was used?
Re: non starter
Postby piet smith » Sun Feb 14, 2010 1:51 pm
MinorMatt wrote:sounds daft - but when was the oil last changed and what grade was used?
My previous post dissappeared. Could you give advice on this please i have the same problem.
piet smith
Re: non starter
Postby John Grove » Sun Feb 14, 2010 8:56 pm
If it's the DI engine it doesn't have glow plugs. My 91 ambulance occasionally needs a shot of the dreaded Easy Start. They say you shouldn't use it - but WW11 tanks used it as standard so I'm told. Batteries need to be in a good state of charge, and I always put the clutch down so that the starter motor doesn't have to pull the thick oil in the gearbox over too.John G
John Grove
Re: non starter
Postby piet smith » Sun Feb 14, 2010 9:01 pm
Thanks John, i have been reading this forum the whole afternoon, i may just stick to Tranny's from now on. :) I read somewhere that you should use 10w40 oil which i will get the garage to use when i take it in for a service. I bought a jump start pack and stepped on the clutch when i tried to start it, it fired up straight away. Hope it does the same tomorrow morning.
piet smith
Re: non starter
Postby dav3pops » Tue Feb 16, 2010 11:51 pm
i havnt changed the oil at all since i bought it 9 mnths ago.......
dav3pops
Re: non starter
Postby MrMPuk » Wed Feb 17, 2010 12:13 am
Have a read through the thread below.
viewtopic.php?f=40&t=9554&start=0
Re: non starter
Postby piet smith » Thu Feb 18, 2010 10:33 pm
Thank you. I did that and learned a lot.
piet smith
