N reg 2.5d Transit. HG Change
Postby paul_elwell » Fri Feb 12, 2010 10:53 am
Van got a little hot last night on the motorway and the HG has now failed.
Hard job to change?
paul_elwell
Re: N reg 2.5d Transit. HG Change
Postby MinorMatt » Fri Feb 12, 2010 5:51 pm
Not particularly if the rocker cover bolts arnt rusted out :lol:
One tip I was given is to use a genuine H/G unless you want to be doing the job again in a few weeks
Postby paul_elwell » Fri Feb 12, 2010 6:46 pm
Just starting mine now
No Haynes manual till tomorrow
What needs to come off?
paul_elwell
Postby paul_elwell » Fri Feb 12, 2010 7:20 pm
Rocker cover off
Air pipes moved out the way
EGR pipe removed
Inlet manifold got to come off?
paul_elwell
Postby MinorMatt » Fri Feb 12, 2010 7:54 pm
no inlet mani can stay on...
easier if you remove the exhaust manifold...
Rockers need to come off too
Postby paul_elwell » Fri Feb 12, 2010 8:15 pm
Ok sweet
Are the rockers not held by the head bolts?
paul_elwell
Postby MinorMatt » Fri Feb 12, 2010 8:20 pm
nope
Postby paul_elwell » Fri Feb 12, 2010 8:23 pm
Sorry being dumb, just ran back to the pc to correct myself - lol
paul_elwell
Postby paul_elwell » Fri Feb 12, 2010 9:23 pm
Anyone got head bolt torque settings?
Also for rockers? Thanks
paul_elwell
Postby jay » Fri Feb 12, 2010 10:32 pm
stage 1 - 52lbf or 70nm
stage 2 - 52lbf or 70nm
stage 3 - angle tighten 90degrees
mk1 connect tourneo
jay
Postby psv-hgv-flt » Fri Feb 12, 2010 10:46 pm
re do the valve clearance's and lightly oil the threds and tops. o and tight um a bit more. (with a scaff pole) :lol: :lol:
psv-hgv-flt
Postby paul_elwell » Fri Feb 12, 2010 11:11 pm
All head bolts out
Injectors still in
Exhaust off
Still stuck down, does it just want a smack?
Paul
paul_elwell
Postby psv-hgv-flt » Fri Feb 12, 2010 11:15 pm
paul_elwell wrote:All head bolts out
Injectors still in
Exhaust off
Paul
DO NOT drag the head (lift) as it will damage the injector nozzle's.
psv-hgv-flt
Postby paul_elwell » Fri Feb 12, 2010 11:20 pm
I see so lift it up square?
So I take it the head sits on dowels and is just a bit stuck?
paul_elwell
Postby psv-hgv-flt » Fri Feb 12, 2010 11:24 pm
yes, if you have got it all undone.
psv-hgv-flt
Users browsing this forum: Google [Bot], steve 06
