transit fuel pump on ldv?
Postby BUNGAL » Thu Feb 11, 2010 1:56 am
Im sorry its about a ldv, with a transit engine. are the fuel pumps the same my mate has got a r reg ldv pickup and the pump has gone dwn. i have a s reg transit in my yard with a rod through the block can i change the pump over? im not sure if his is a turbo or not i havent seen it yet. any help would be great.
BUNGAL
Re: transit fuel pump on ldv?
Postby ake » Thu Feb 11, 2010 7:36 am
Presuming they are both 76 ps (Banana manifold) Yes, but are you sure he has a Transit engine, Were LDVs not still on Peugeot engines on R reg :?: I know they had the MT75 box by then :?
Postby psv-hgv-flt » Thu Feb 11, 2010 11:00 am
late r,reg was ford, that is the year they changed . :wink:
psv-hgv-flt
Postby BUNGAL » Thu Feb 11, 2010 7:08 pm
It got a transit engine but i think the van in my yard has di without the bannana manifold. arent the engines the same any way?
or does the bannana engine have a belt driven pump?
BUNGAL
Postby Altransit » Thu Feb 11, 2010 8:09 pm
All the Di engines have a belt driven pump, so the Transit one should work ok :wink:
Postby MinorMatt » Thu Feb 11, 2010 8:16 pm
S reg is changeover for the emissions criteria. If the injectors havent got the same numbers swap them over too
Postby Altransit » Thu Feb 11, 2010 8:22 pm
I have just noticed that you're not sure if the LDV has the turbo engine .....................
If it has, then the pump wont be a straight swap, as these have the Lucas EPIC system :wink:
Postby BUNGAL » Fri Feb 12, 2010 8:27 pm
Altransit wrote:All the Di engines have a belt driven pump, so the Transit one should work ok :wink:
IS MY ENGINE IN MY VAN NOT A DI THEN I HAVE JUST LOOKED AND IT HAS A MACHANICAL PUMP THAT RUNS FROM THE BACK OF THE ENGINE PROBLY FROM THE CRANK? OR AM I LOOKING AT SOMETHING ELSE.
BUNGAL
Postby Altransit » Fri Feb 12, 2010 8:37 pm
The injection pump is at the front of the engine, on the drivers side, just behind the timing cover :wink:
Are you sure that the LDV has a Transit engine? It is possible that it has the older Peugeot lump :roll:
Postby GBBiker » Fri Feb 12, 2010 8:39 pm
If itt's a 1998 LDV, it will be a Ford Di engine. Either 76ps 'Banana' or 85ps Turbo.
My old 97 Convoy was a Di.
GBBiker
Wrong Again!
Postby Altransit » Fri Feb 12, 2010 8:41 pm
If it's an "R" reg, it could be 1997, changeover year for these engines :wink:
Postby BUNGAL » Sat Feb 13, 2010 12:26 am
The ldv has a transit engine with a bannana manifold. i will look at the van in my yard tomorrow but im sure it looks different.
BUNGAL
Postby Altransit » Sat Feb 13, 2010 12:31 am
OK, so long as the LDV has a Transit engine, then your Transit engine will be more or less the same motor, if it is a diesel! It may not be a banana engine, and it could be a turbo, but the pump will be in the same place, even if the pump itself is different :wink:
Postby grollie » Sat Feb 13, 2010 3:51 pm
We have a R reg LDV Convoy pickup TDi. If the engine isn't a banana 2.5 Di then probably it's a Turbo Engine with the EPIC electronic system.
You can change the pump to a manual pump and cable control. I done this over a year ago on our convoy TDI and still running
grollie
Postby BUNGAL » Sun Feb 14, 2010 9:22 am
ALL SORTED.
changed the pump and injectors from my naff van, ldv is back running. nice one cheers for all the info. :D
BUNGAL
cron
