Clutch
Clutch
Postby shambles » Mon Feb 15, 2010 9:16 pm
I've got a 54reg 350 lwb high roof factory petrol/lpg, i think the clutch is on the way out as quite hard to engage some gears and seems to be slipping under hardish load + in stop start traffic a bit jerky cluncky.......Could any one advise on what clutch i need and any suggestions as to the cheapest available, cheers Alan
shambles
Re: Clutch
Postby jonb1 » Tue Feb 16, 2010 1:01 pm
hello mate im not sure on the petrol but on the diesel i always fit a valeo solid flywheel conversion kit comes with flywheel clutch kit etc for around 200 quid never have any problems also next time it needs a clutch you dont need to replace flywheel i would exspect valeo to do a kit worth a google & phone round motor factors hope thats some help
jonb1
Re: Clutch
Postby shambles » Sun Feb 28, 2010 11:33 am
Ok clutch is slipping really badly now so its time to put me hand in me pocket, but not sure which clutch is needed for my model, any of you clever bods on here point me in the right dirrection as to which and what clutch i need, cheers Alan
shambles
Re: Clutch
Postby jonb1 » Sun Feb 28, 2010 12:37 pm
i would contact a local motor factor that stocks valeo clutchs & see if they do a valeo solid flywheel conversion kit for your model as said before should be around £200 have fitted a lot of these to diesel vans with no problems if stuggling if you pm me with the details of your van i will see if i can find out for you
jonb1
