Leaking Roof
Leaking Roof
Postby Hughsie » Tue Feb 16, 2010 8:09 pm
Hi guys,
I've just bought a 54 reg swb low roof transit, and i've noticed a leak along the join in the roof at the rear of the van. Theres now some rust forming as well!
Is this a common problem? And any advice on what I can do would be hugely appreciated.
Hughsie
Re: Leaking Roof
Postby ake » Tue Feb 16, 2010 8:15 pm
Yes its a common problem because Ford never put any sealer on the joint, the MK7s have a run of sealer along it, You need to dry it out and then seal along the seam with seam sealer or similar
Re: Leaking Roof
Postby large-ugly-greeny » Wed Feb 17, 2010 12:18 am
had this problem with my 53 reg in the heavy rain October last year there is a product out there i think it was called seak and seal or something like that it is a fluid and you just run it into the crack and it sets with a rubber solution (flexible) then i had a epoxy radiator sealant over the top of it and it has been bone dry ever since
will find the rubberizing stuff if you want a product name as it worked wonders
large-ugly-greeny
Re: Leaking Roof
Postby Hughsie » Thu Feb 18, 2010 6:30 pm
Yes please! I'd love a product name. Just don't want it getting any worse, the rest of the van's mint.
Thanks for the replies guys, Chris
Hughsie
Re: Leaking Roof
Postby madmark » Thu Feb 18, 2010 6:43 pm
the later mk6 has a selaed join the same at the 7 ,erly mk6 vans suffer badly with this problem! :roll:
Re: Leaking Roof
Postby boothy » Sat Feb 20, 2010 11:13 am
Used kitchen silicone and a paint brush on mine :lol:
boothy
Re: Leaking Roof
Postby Guy88 » Sat Feb 20, 2010 1:30 pm
boothy wrote:Used kitchen silicone and a paint brush on mine :lol:
will rot the metal :wink:
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Re: Leaking Roof
Postby trigger » Sat Feb 20, 2010 3:04 pm
They rot anyway :wink:
Mk5 Transit the daddy
trigger
Re: Leaking Roof
Postby stevo » Sat Feb 20, 2010 3:24 pm
:lol: :lol: I put copper grease on mine :lol: it worked but i just get covered in brown sh*t everytime i take my ladders off :lol:
Formely ibanez2005
2003 100 T260 TDDi swb
stevo
Re: Leaking Roof
Postby jockster the chippy » Sat Feb 20, 2010 5:52 pm
there is a product called CT1 which you can use an wet or dry surfaces it is great and solvent free I use it for sealing window frames on a building that sits 10 feet from the sea can be obtained from good builders merchants used with a normal mastic gun :D
If Carlsberg made vans they would copy the TRANSIT
jockster the chippy
Re: Leaking Roof
Postby trigger » Sat Feb 20, 2010 7:40 pm
ibanez2005 wrote:it worked but i just get covered in brown sh*t everytime i take my ladders off :lol:
The managers where i used to work get covered in Brown sh*t everytime the bosses come in :lol: :lol: :lol:
trigger
Re: Leaking Roof
Postby large-ugly-greeny » Sun Feb 21, 2010 10:26 pm
found the product i was on about
made by this company http://www.captaintolley.com/
its called captain tolleys creeping crack cure
apparently can get it from chandeliers and mariners as its widly used in boats
then over the top i had some halfords radiator and water pipe jolop that sets hard but is rubbery and sticks to metal so that has completely fixed the leaks
hope that helps
large-ugly-greeny
Re: Leaking Roof
Postby frog_southampton » Mon Feb 22, 2010 10:01 pm
So...........
What would be the best and safest thing to fix a leakey MK6 roof with out causing any more damage?
frog_southampton
Re: Leaking Roof
Postby Hughsie » Wed Feb 24, 2010 12:48 pm
Thanks Greeny!
I'll get onto it as soon as the weather dries up a bit... :?
Very helpful, thanks again
Hughsie
Users browsing this forum: Chrispduck
