It is located in the hidden fusebox. See
It is listed in the instruction book as 'Battery Saver OBDII'
martynx wrote:If you cant connect diagnostically, via the OBD socket , that fuse is the culprit as well !
DanIsADude wrote:I would class it as a few moments. I got in the back of the van and shut both doors and waited 30 seconds or so, they were still on. Does it take longer than this?
