52= twin wheel
53= twin wheel a series (different mounts,wont fit transit)
jnwferguson wrote:Hi guys has anyone fitted a jag axle to there transit I know the front axle comes on a subframe so should be an easier fit than a lot of other axles also you can get a fitting kit for the rear I was considering this for my mk2 change both axles and have full independant suspension and power steering and most jag axles are 58" wide.
cheers jim.
mk2 camper
mk2 4x4
ginsambo wrote:Anyone have any info on a heavy duty custom twin wheel axle swap for a Mk5-7 chassis cab without the diff casing bottoming out?
What I gather is Merc Sprinter (Dana?) axles can be loaded with spares from America, but still they're a little narrower track than a Transit..
Even an F350 is slightly narrower than a Transit twin axle...now I'm just being obsessive eh!
F250 F150 way too narrow and load rating not sufficient.
Anyone any info on a wide track load rated dually axle?
Luke wrote:Rolo's idea - look here for origanal post!!!!
We need to compile a usefull information thread on rear axles - what fits what and whats on what!!!![]()
I think it will take more than 1 person to do this so add as much info in this here in this thread and i will sort it all out to one post!!![]()
make sure you use the mk or the year so we know what were talking about!! look here to find which mk is which!!!!and also state if its SWB or LWB single or twin your talking about!!!!
so basically post any info you have on rear axles here
