Flat spot
Flat spot
Postby The General » Fri Apr 02, 2010 10:58 am
Just had to change the injectors on my mk5 2.5d n/a 70ps as i got a bit ham fisted changing the leak off pipes (broke the plastic outlet on one of them :evil: ). It had white spot injectors in it, these ones
So got a set of the later red spots from the scappy. and now its got a occasional flat spot/holds back at about 2000rpm?
I've tried adjusting the fueling(torque sleeve thingy) to see if it needed more fuel, but did'nt make much difference. And just put some Redex diesel cleaner in it, but wont know if this has done anything yet till I take it for a long run.
Any idea what could be causing this? Its rearly P'ing me off because it ran fine with the old ones in. Teach me to fiddle with it wont it :oops: .
The General
Re: Flat spot
Postby AndyG » Fri Apr 02, 2010 12:57 pm
You CANNOT simply go by the coloured dots on the injectors :!: :!: :!:
You need the numbers off the old ones, as they are matched with the pump :!:
Injectors and pumps vary according to application AND date of manufacture, in accordance to power and emissions specification :!:
Re: Flat spot
Postby The General » Fri Apr 02, 2010 5:54 pm
Ok, sorry this is my first transit AND first diesel. So I dont know much about them. I'm more used to working on 70's ford petrol engines. So, where are the numbers on these^ injectors? And is it possible to have my old one repaired?
Edit=
Found this number after a good clean with a wire brush - 30678.
On the new ones is 33708.
The General
Re: Flat spot
Postby The General » Sat Apr 03, 2010 11:54 am
Managed to sort out my old injectors, got hold of a second set of old style ones like in the picture and changed over the plastic bit on the top. So now all sorted :D
The General
Re: Flat spot
Postby AndyG » Sat Apr 03, 2010 4:48 pm
Well done :!: :D
Re: Flat spot
Postby matthew2riches » Sat Apr 03, 2010 5:04 pm
The General wrote:Ok, sorry this is my first transit AND first diesel. So I dont know much about them. I'm more used to working on 70's ford petrol engines. So, where are the numbers on these^ injectors? And is it possible to have my old one repaired?
Edit=
Where abouts are the numbers? I still need to find a new set for mine :(
matthew2riches
Re: Flat spot
Postby AndyG » Sat Apr 03, 2010 5:53 pm
EG;
Arrow shows where the over acclaimed coloured spot normally is :D
And no, that's not a pic of my engine :!: :o :lol:
