The Transit County of Essex!
Postby Eugene Speed » Wed Mar 03, 2010 2:02 am
Since becoming the proud owner of my Mk3 1991 County LWB, I have been constantly looking for modifications and improvements to do, some of which I have had done on previous vans I've owned or worked on, and others that have been inspired from other Transit owners and modders (mainly on these forums!). Some of the jobs will be purely functional as this is my work vehicle as well as my daily driver. A few of the mods will be just for the sake of it, and lets face it they are usually the most fun to do!
First job was to swap out the slightly suspect 2.5di engine that was noisier than I would have liked it to be, replacing it with the recently reconditioned engine out of my now scrapped Mk4 SWB.
viewtopic.php?f=15&t=61531
Next job was to make her a bit more secure, so I pulled a favour from my mate Nick (the welding world's equivalent of The Stig) and had some super-tough grilles welded into the rear windows and into the centre bulkhead, making the rear load area nice and secure. He also fitted my rear door padlock hasps, seam welding both sections solidly to the doors and adding further reinforcing webbing inside the rear door cavities.
As this is my work van, I had to sort some storage and shelving in the rear load section, this included making some much-needed repairs to the existing ply lining and then forming a shelving unit above each rear wheel arch boxing. Thanks to my good mate Oliver for the use of his driveway and workshop, and the free supply of wood!
A spare Saturday morning resulted in a new exhaust system, totally uneccessary but absolutely worth it! viewtopic.php?f=13&t=61697
Next came the task of removing all the dead wiring left over from the van's days as a fire and rescue vehicle, all the 'blues and twos' had been removed but the wiring system was still there, though in somewhat of a state. The dash surround had been drilled for a multitude of toggle switches and panel lamps, most of which were broken or looked in a poor state. Behind the dash panel was like a rats nest of cabling, so every cable was removed, checked for dead then cut and taped up, I chose not to strip them out completely as they may be useful at a later date. Most of this extra wiring loom ran through the front bulkhead and into the engine bay, connecting to a bank of six relays. These were all labelled as 'spots', 'fog' and 'blue', again indicating the van's previous history as an emergency vehicle. Again, I have left the relays in place for use further down the line. Suprisingly the alternating relay for the old style two-tone horns was still fitted and powered up ok, I may just have to do something with that someday! :wink: Thankfully I had removed the dash surround from my Mk4 which was unmolested, so this has been fitted in place of the drilled one to give a cleaner look. Whilst the dash was off I took the opportunity to remove the green caps from the dashboard illumination lamps, now I can actually see my speedo and fuel gauge properly at night!
The van had a second battery tray on the passenger side so I have fitted another battery identical to the starter battery and connected the two with heavy duty starter cable, at the same time adding extra negative cables from both batteries to the engine block and also the chassis. A third battery now lives in a battery box under one of the seats in the crew cab area, fed from the second starter battery via a Smartcom self-switching split charge relay.
The heater panel surround including the blower fan control and cigar lighter was in a poor condition as it had many holes left from having things screwed into it at some time, once again the Mk4 was raided and the panel replaced.
The most recent job involved fitting the alarm/immobiliser system, without going into too much detail I have used two different systems to make one very effective anti-theft unit, which incorporates a remote engine starting/warm-up feature as well as a proximity anti-hijack system and a two-way paging/control unit made out of some old PMR radio sets.
Thats as far as I have got to date, next jobs on the list are fitting interior striplighting and a fuse/switch panel for the auxilliary battery, full central locking for all doors integrated into the alarm system, and adding a couple of extra worklights over the rear and side sliding doors. As far as bodywork goes, Nick the welder is planning to chop out the sills and weld in some box section steel and side rails ( I think the off-road crew call them rock sliders) so there is no more worry about rusty sills ever again! He also has designs on making a front winch bumper and nudgebar setup from scratch, which will probably get started toward the end of this month.
Also a mention for the chaps at Southern Tyre Wholesalers in Westcliff who have done me a fantastic deal on a set of four Deestone Extra Traction tyres, though I think that they dropped the price just to get the things out of the way! Just need to find a couple more then I'll get the lot fitted in one go.
I'll post up some more pics soon, have got to go to Maplins to get a new battery for the digital camera, I could use my camera phone but they dont come out too clever on a bigger screen.
Thanks for all the help, advice and positive feedback from fellow Transit lovers, hope to meet as many of you at some of the meetings planned for this year. A127 Diner on the 8th is a deffo!
Last edited by Eugene Speed on Thu May 20, 2010 10:16 pm, edited 3 times in total.
91 Transit County 4x4
88 Transit 130 armoured van
99 Transit spec lift
90 Fiat Panda 4x4
http://facebook.com/eugene.speed
http://tuffcomputercompany.com
http://transitcounty4x4.co.uk
http://truthsearchersuk.org
Member of the Mk3 Massive! :)
Eugene Speed
Re: My County 4x4
Postby AlanN » Wed Mar 03, 2010 5:31 pm
Nice start to your 'Progress Report' and I would add your text & photos from your exhuast thread to this one, just help to keep it all together :D Look forward to seeing you at the 127 Diner meet next monday 8)
Re: My County 4x4
Postby Eugene Speed » Fri Mar 26, 2010 2:57 am
Got lucky today and found a set of bash bars for the wagon, bargain at twenty quid! :mrgreen:
I've already had ideas to modify them a little, going to copy the 'people plough' style that was much favoured by the plod on their riot vans!
Got a bigger roof racking system to go on as well, with catwalk and drop-down rear ladder, yet another scrapyard bargain! Will have a go at fitting it over the Easter break, pics will be posted... :wink:
90 Fiat Panda 4x4
Eugene Speed
Re: My County 4x4
Postby Eugene Speed » Fri Apr 09, 2010 8:49 pm
Newly restyled bullbars are now back on the van, once again huge thanks to Nick for his awesome metalworking skills, and also to Andy at Fawkes & Lewis http://www.fawkesandlewisltd.com for the use of the workshop and equipment.
The bars I got from the scrapyard for a score, before Nick started chopping them up!
The new tubing is shaped and tacked into place.
Driver's side tubing tacked into place.
Nick welding it all up!
New bars back on the van.
New bars with a bit of paint on!
I also added some extra roof bars, a ladder holder and a drop-down rear ladder for getting up on top of the van, complete with walkway and lighting brackets.
Thats all for now, hopefully I will get some time in the next couple of weeks to get the interior electrics sorted, and the stereo fitted. Also found that one of the front suspension mounts is a bit too rusty for my liking so going to get a new one ordered and let Nick work his magic fitting it!
90 Fiat Panda 4x4
Eugene Speed
Re: My County 4x4
Postby d&d plumbing » Fri Apr 09, 2010 11:07 pm
Chuffin' 'ell
What you expecting to meet on the motorways!!!!!!!!
:shock:
2010 140 Limited SWB/LR Double Cab. Sea Grey
d&d plumbing
Re: My County 4x4
Postby dirtydog » Fri Apr 09, 2010 11:23 pm
d&d plumbing wrote:Chuffin' 'ell
:shock:
Hopefully not me!!! :shock: :shock: :shock: :wink:
dirtydog
Re: My County 4x4
Postby Eugene Speed » Sat Apr 10, 2010 6:00 am
:shock:
BMW 3 series and Nissan Micras hopefully.... ;)
Seriously, the way some of the idiots in my town drive, I'd rather put a few extra inches and kilos of metal between us! I swear that the matt black paintwork on the van must have come from the military as it has incredible 'stealth' properties. I've already had one tangle with a car and the driver claimed he didn't see me. I asked exactly which part of the HUGE bloody Transit he 'didn't see'?!?! :roll: Since the bars went on, not so many people are as keen to get in front of it. :lol:
Just wait until you see the rock sliders we are putting on next. :mrgreen:
90 Fiat Panda 4x4
Eugene Speed
Re: My County 4x4
Postby AlanN » Sat Apr 10, 2010 12:40 pm
A Flouro red paint job might help... :lol:
Re: My County 4x4
Postby dirtydog » Sat Apr 10, 2010 3:44 pm
Eugene Speed wrote:BMW 3 series and Nissan Micras hopefully.... ;)
I used to drive a 12t armoured Iveco around and you'd be surprised how many people "didn't see" me :roll:
dirtydog
Re: My County 4x4
Postby Guy88 » Sat Apr 10, 2010 4:35 pm
try a bright orange RAC transit, had someone walk into it at a zebra crossing :o
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Re: My County 4x4
Postby dirtydog » Sat Apr 10, 2010 8:08 pm
Guy88 wrote:try a bright orange RAC transit, had someone walk into it at a zebra crossing :o
Ha ha sounds about right. people are so stupid!
dirtydog
Re: The Transit County of Essex!
Postby Eugene Speed » Thu May 06, 2010 6:31 pm
Got a couple of new tyres fitted, some lovely Deestone Extra Traction 7.50x16, thanks to the chaps at WJ Woods for the superb service and speedy fitting.
http://www.wjwoodretailtyres.co.uk/index.asp
Will be getting the other four tyres changed in the coming few weeks. The Deestones are so much quieter on the road than the BlackStar Guyane that they have replaced, and look much better too! :wink:
Will be tackling some extra electrics next, more pics to follow.
90 Fiat Panda 4x4
Eugene Speed
Postby Eugene Speed » Fri May 21, 2010 8:57 pm
Added a new switch/fuse/meter panel in the crewcab area today, operates the rear and side mounted work lights and crewcab/loadspace interior lights.
Also fitted a reversing camera and 3.5" TFT screen.
A solar panel keeps the starter batteries topped up.
And an extra ten-way fuse panel mounted under the glovebox, half the fuses are permanently live and the other half are live with the ignition on.
Next up is the remote operated relay for the worklights, and some LED striplighting for the cab area. I also have a digital GPS speedometer to fit in the dash, hopefully will get a day free in the next couple of weeks to get these bits sorted!
90 Fiat Panda 4x4
Eugene Speed
Postby transitandy » Fri May 21, 2010 11:33 pm
great work m8y love the nudge/wrecker bar :wink: :) 8)
Postby Eugene Speed » Thu Jun 17, 2010 12:44 am
New Deestone ExtraTraction tyres all round, and decided to paint the rims satin black.
Got some new lights to fit next week so should have some more pics to post soon.
90 Fiat Panda 4x4
Eugene Speed
