engine and chassis numbers
Postby westewoo » Sun Jul 02, 2006 2:07 am
hi gang. new to this site and also the trannys.
can anyone tell me were the engine and chassis numbers will be on a 90t350? (2.4 dura torque)
the other quicky, if tried to reset the service light with the break/throttle method, but it hasnt worked, any idears ?
anyone convering there van into a camper, have a look at http://www.sbmcc.co.uk for hint and tips. all the best. steve in wigan :D
westewoo
Postby 100ps_drw_hicube » Sun Jul 02, 2006 2:26 am
welcome :wink: :lol: nighthawk will be your man 8)
100ps_drw_hicube
Transit Abuser!!
Postby Nighthawk » Sun Jul 02, 2006 10:16 am
You'll find the chassis number on it's sticker on the N/S B pillar, it's also displayed in the N/S lower corner of the windscreen.
Both of these places use anti tamper stickers and will tear off if someone tries to remove them.
The chassis is stamped inside the O/S front wheel housing.
look in the area around the water drain tube exit, you'll see two straight lines forned into the panel, the number is between those.
The engine number is much harder to spot as it's obscured by the turbo charger
How were you trying to reset the service light and which icon do you have?
press and hold the brake and throttle pedals
turn on the ignition to pos II
after about 15-20 seconds the light will flash (orange oil can) or go out (red spanner)
you'll know when it's about time, because your left leg will start to ache ;)
relase both pedals at the same time and turn off the ignition
count to 10 and then turn the ignition back to pos II
the light should no go straight out.
Transit.........Job done
Nighthawk
Postby westewoo » Sun Jul 02, 2006 1:53 pm
thanks nighthawk, the sevice light icon is orange and has a spanner and dripping oil can on it. i will try it again, as with you saying your left leg will ache, i take it you push the brake down hard, and all ive done was enough to light the brake lights. :shock:
westewoo
Postby Nighthawk » Sun Jul 02, 2006 5:46 pm
done it?
:lol:
Nighthawk
Postby westewoo » Sun Jul 02, 2006 11:09 pm
no boss. its not worked. do you think the battery off overnight might do the trick, or is it time to get either the bulb out or fleeced at fords?
westewoo
Postby Nighthawk » Mon Jul 03, 2006 9:37 pm
there is something ODD here!
A ford dealer can only reset the light in the manner I have posted, leaving the battery disconnected is unlikely to work either.
Removing the bulb from the system can lead to a lack of power too, so don't do that.
Have another go at it before you consider going to a dealer, it may well be a problem within the PCM
A calibration update is a possible fix, either that or it's time for a new module :shock:
Nighthawk
Users browsing this forum: samc1992
