Cheers!
MONSTER 0NE wrote:I have used the early espace swivels on both my front seat in my van (there are pics in my progress thread), but need to shorten the base to accomidate the extra height of the swivels. But since I have done mine I have spotted that the peugeot 806 has a better design, with the swivel sunk in the middle so the extra height of the swivel is a lot shallower than the espace ones if that makes sense.
spudmab wrote:MONSTER 0NE wrote:I have used the early espace swivels on both my front seat in my van (there are pics in my progress thread), but need to shorten the base to accomidate the extra height of the swivels. But since I have done mine I have spotted that the peugeot 806 has a better design, with the swivel sunk in the middle so the extra height of the swivel is a lot shallower than the espace ones if that makes sense.
what sort of year 806, does it have to be top of the range model
alexthecheese wrote:After one of these so I can turn the seat around in my bus for stretching out when we're stopped.Any ideas if there's any about, or a base for a different van/chair that I can use? Had a rummage through the forums and Google but nothing stands out.
Cheers!
Choppergeoff wrote:alexthecheese wrote:After one of these so I can turn the seat around in my bus for stretching out when we're stopped.Any ideas if there's any about, or a base for a different van/chair that I can use? Had a rummage through the forums and Google but nothing stands out.
Cheers!
Hi Alex. I've just fitted a pair of swivel bases to my standard captains seats , (both singles) using a pair of American aftermarket bases from a Chevy van.
I cut down the runners , reduced the slide handle , fabricated new base to the swivel, cut the standard seat frame down to use the hight and tilt levers.then welded the seat base to the top of the swivel. re-located seatbelt anchor
bit of paint
job done.
I can turn it through 360 degrees with a little messing .
good luck Geoff
