EPIC to 686 manual pump, new auto belt tensioner. PICS
Postby psv-hgv-flt » Fri May 07, 2010 8:51 pm
psv-hgv-flt
Re: EPIC to 686 manual pump, new auto timing tensioner. PICS
Postby MrMPuk » Fri May 07, 2010 8:53 pm
Postby the.little.fatboy » Fri May 07, 2010 8:56 pm
where is the pics then psv-hgv-flt as johnnyk needs some help with timeing :D :D :D
if it brakes fix it if you cant fix it scrap it and buy a ford transit
also collecting scrap metal in northampton and milton keynes area's
the.little.fatboy
Postby psv-hgv-flt » Fri May 07, 2010 8:57 pm
the.little.fatboy wrote:where is the pics then psv-hgv-flt as johnnyk needs some help with timeing :D :D :D
DONE. :wink:
psv-hgv-flt
Postby the.little.fatboy » Fri May 07, 2010 8:58 pm
sorry i see them now :lol: :lol: :lol:
the.little.fatboy
Postby V184 » Fri May 07, 2010 9:03 pm
How much is a recon epic pump then ?
V184
Postby johnnyk » Fri May 07, 2010 9:04 pm
Spot on- thats the one, thanks psv/little.
tool of britain
johnnyk
Postby MrMPuk » Fri May 07, 2010 9:07 pm
Should they be in order?
Postby psv-hgv-flt » Fri May 07, 2010 9:12 pm
the chap i did this for was priced £650.00 to take pump off test (just test) and replace (nackerd) not even fixed. i got the local diesel pump chap to make one up to spec. (£425.00) recon with warranty.
psv-hgv-flt
Postby psv-hgv-flt » Fri May 07, 2010 9:13 pm
MrMPuk wrote:Should they be in order?
should be, but=??
psv-hgv-flt
Postby sideshow_bill » Fri May 07, 2010 9:39 pm
Should you be showing what a pump looks like with the PATS removed????? ;)
sideshow_bill
Postby dibs » Fri May 07, 2010 10:01 pm
Nice pics. little bit muddled up though :? About time for a good guide to the conversion as there seems to be enough of us doing it. Nice one! Am I right that the 145 pump has no PATS/immobiliser thingy and the 146 does being the difference between them?
1990 LWB Mk3 twin wheel 190 minibus (My favourite but stolen)
1998 LDV Convoy Ford DI engine but... yuk, yuk, yuk (bought in desperation, sold 2 months later)
1997 SWB Mk5 minibus (Great but small)
2001 LWB Mk5 TD 100ps Minibus (hmm..)
Get me to that gig!
dibs
Postby MinorMatt » Fri May 07, 2010 10:06 pm
they do both have PATS, the pic there shows the module removed. (which to be honest is far from difficult!)
the difference is a very slightly different fuel map
Postby psv-hgv-flt » Sat May 08, 2010 5:22 pm
as MinorMatt says, (easy when off) :wink:
psv-hgv-flt
Re: EPIC to 686 manual pump, new auto belt tensioner. PICS
Postby MinorMatt » Sat May 08, 2010 6:15 pm
having said that you do get smileys without PATS from the factory - either a special order or non UK spec - those can have non PATS 145/146 pumps too
