Body work has begun
Body work has begun
Postby rob-xcar » Mon May 10, 2010 4:47 pm
The time has come for my van to be painted so its off to the bodyshop for a nice coat of performance blue and a few suttle body mobs.
First job on the list is the fitment of two sets of rear connects arches . When in place they look brilliant.
As you can see from the last image I have retained some of the original fixings to allow for easy fitment. Be nice to hear what you all think about it as I personaly think it looks top.
rob-xcar
Re: Body work has begun
Postby Luke » Mon May 10, 2010 5:28 pm
looking forward to reading about this one 8) 8) looking good so far :!: can't beat flared arches for looks :mrgreen: :mrgreen:
Postby matthew2riches » Mon May 10, 2010 6:27 pm
Are they connect arches?
matthew2riches
Postby rob-xcar » Mon May 10, 2010 6:50 pm
Yes they are connects arches but im only using rear ones. due to there shape.
rob-xcar
Postby bigmastif » Mon May 10, 2010 8:24 pm
sweet looking forward to your progress, sounds like it will be a psycho van esq van 8)
bigmastif
Postby chipv8 » Tue May 11, 2010 1:10 pm
Looking good, nice idea with the arches. Where's the front bumper from? Is it a one off or a production part - I.E. available......?
Back In the Black Country!!
chipv8
Postby rob-xcar » Tue May 11, 2010 8:59 pm
Got the front bumper off the van shop many years ago and its been modified to fit the mk5 as it was designed to fit the mk3. See the my vans post
rob-xcar
Postby Gurj51ngh » Tue May 11, 2010 9:14 pm
That is looking sweet mate! 8)
Gurj51ngh
Forums Loudest Van!
Postby rob-xcar » Mon May 17, 2010 6:52 pm
Little bit more progress on the arches today , Managed to fit both rears and started cutting the front N/s to allow door to open.
Only problem i've had is the windscreen sealer I used hasn't bonded to the plastic arch so its back to the drawing board(any suggestions welcome.Image
there is a small section that is tobe fitted to the door and the space between is to be filled.
As you can see from the last picture I have cut the arche to allow original bumper to fit underneath. They are not totally central but I can live with it...
Just need to work out how to space the sliding door to clear the new arche
As can be seen in a previous post I managed to mark out and drill the rear panel to alow the use of the original body clips. this worked so well that I couldn't get the bugger offf earlier.
rob-xcar
Postby AlanN » Tue May 18, 2010 12:32 am
Looking really good 8) , colour coding them aswell?
TransitTrevs connect arches look a bit different to yours, they seem to slope in to the body at the bottom, maybe he cut them...
Postby projectzip » Sat May 22, 2010 10:23 pm
Im loving those arches!
Wonder if they would work on the 15" arches on my LWB hmmmmmmmmm
My Race Support Vehicle / Camper Project www.exit13.biz one off graphics to full race car livery's.
projectzip
Postby WINDSCREENGUY » Sat May 22, 2010 10:26 pm
windscreen sealer will work but you have to prime both surfaces
formally grey van man.
WINDSCREENGUY
previously grey van man
Postby rob-xcar » Sun May 30, 2010 11:08 am
We have had some progressImage
they have repaired some rust in the top corner behind the screen and have straightened the gutters. We had a bit of rust behind the sliding door rail but not to much.The bonnet is back to bare metal due to an over zelous trainee . Top tint windscreen ordered for when its finished and all holes drilled for arch fitment.
rob-xcar
Postby darkbluevanman » Sun May 30, 2010 3:45 pm
Top tint, top mod :) , by the way, what thickness are your wheel adapters and what fitting wheels are they now..
darkbluevanman
Postby Luke » Sun May 30, 2010 7:03 pm
looking good 8) 8) can't wait to see this done :D
