Bad boy bonnet
Bad boy bonnet
Postby trigger » Mon May 17, 2010 11:00 pm
How easy or hard is it to make a bad boy bonnet? i fancy one on my van but i'm no good at welding, plus i would have to get it resprayed, does anyone have a good spare bb bonnet kicking around that they are not using?
Mk5 Transit the daddy
trigger
Re: Bad boy bonnet
Postby AndyJ2506 » Tue May 18, 2010 7:43 am
You won't need to weldd it as the vent will be fiberglass you will just need to bond it in place with sika flex or similar. There's quite a few vents on eBay that don't even require a hole cutting as there purely cosmetic. Hope this helps :D
Call 07739463511
AndyJ2506
Re: Bad boy bonnet
Postby matthew2riches » Tue May 18, 2010 7:48 am
If you are on about covering the lights a little like most on here, you could cut the steel and then glue it in place. Providing you have enough contact area - they'll hold. It's not as if it holds and weight. Then you've just got to fill, sand and paint.
Worth it when it's done :!:
matthew2riches
Re: Bad boy bonnet
Postby trigger » Tue May 18, 2010 8:19 am
That's the bit i was thinking about, the "eyebrows" not vents, seen a few on here and thought they looked cool, i suppose if i glued them on i would have to be careful in shutting the bonnet in case they cracked
trigger
Re: Bad boy bonnet
Postby trigger » Tue May 18, 2010 8:27 am
Just had a thought, if i got another bonnet to do it on and i make a complete hash of it then at least i won't have ruined my original bonnet
trigger
Re: Bad boy bonnet
Postby BROWNYS V6 » Tue May 18, 2010 8:25 pm
i got a pair of smiley bonnets in my garden, could bad boy it aswell :wink:
how much you wanna pay :lol:
BROWNYS V6
Re: Bad boy bonnet
Postby trigger » Tue May 18, 2010 10:25 pm
How much are you offering them for? there's a couple on ebay one starting at £20 with no bids and another at £25 buy it now
trigger
Re: Bad boy bonnet
Postby AndyJ2506 » Wed May 19, 2010 8:57 am
Sorry got the wrong end of the stick :lol:
have a go yourself matey I've never welded before, that's what fillers for :mrgreen:
Call 07739463511
AndyJ2506
Re: Bad boy bonnet
Postby mr2swzo » Wed May 19, 2010 12:11 pm
I've never fully understood why anyone would wan't a bad boy bonnet on a car never mind a workhorse van? But each to there own. I wounder if ford would have sold as many if they were "bad boy'd" from the showroom? :lol:
mr2swzo
Re: Bad boy bonnet
Postby darkbluevanman » Wed May 19, 2010 7:25 pm
I think browny's monobrow looks a bit more classy :wink:
darkbluevanman
Re: Bad boy bonnet
Postby AlanN » Wed May 19, 2010 7:28 pm
Bad boys are out Trigger, you need browny brow bonnet 8)
unless your driving in the dark :lol:
Re: Bad boy bonnet
Postby trigger » Wed May 19, 2010 7:35 pm
AlanN wrote:Bad boys are out Trigger, you need browny brow bonnet 8)
But his is a mk3
trigger
Re: Bad boy bonnet
Postby AlanN » Wed May 19, 2010 7:50 pm
and your point is! :D
Re: Bad boy bonnet
Postby trigger » Wed May 19, 2010 7:59 pm
AlanN wrote:and your point is! :D
Bonnet on mk5 is different
trigger
Re: Bad boy bonnet
Postby darkbluevanman » Wed May 19, 2010 9:01 pm
Yeah... badge is on grill ;)
darkbluevanman
