MK 7 Transit
MK 7 Transit
Postby xbox360 » Fri Jun 23, 2006 10:34 pm
Saw my first MK 7 today at my local stealers it was a metalic blue one. Had a peep in the window CD player ,elec windows, auto lights, 6 speed, 115ps t350 looked pretty good did not go in it as it was only 7am. has any one seen a better spec (Has any one seen one with leather seats :D )
xbox360
Postby xbox360 » Fri Jun 23, 2006 10:35 pm
Just to add is that a fold away picnic table on top of the dash?
xbox360
Postby Nighthawk » Fri Jun 23, 2006 11:01 pm
Yes it is a fold over table, to which i might add is a poor design from a set up point of view.
Natural instinct tells you to grip it in the middle in order to flip it over, but that results in a trapped hand and a change of grip on it.
The clearence between the table and the screen is too close and it soon becomes annoying......but no one listens to me :cry:
The table is flanked by lift up flaps over storage areas too.
Did you notice the discs on the rear or the button to turn off the stability control system?
Transit.........Job done
Nighthawk
Postby xbox360 » Fri Jun 23, 2006 11:06 pm
I did not notice the discs as it had full size wheel trims on so never thought of looking and no i did not see the button you mention. I will go back tomorow and have a proper look i think.
xbox360
Postby 100ps_drw_hicube » Fri Jun 23, 2006 11:37 pm
are they fitting discs to the drw variants??? :? :?
100ps_drw_hicube
Transit Abuser!!
Postby VJ 6 Aus » Sat Jun 24, 2006 7:35 am
So the MK7 is 4wheel disc is it I didn't see that on the Ford Uk site spec sheet! have they changed the bloody stud pattern to something more reasonable??
VJ 6 Aus
Postby MrMPuk » Sat Jun 24, 2006 8:05 am
Nope, stud pattern is still the same.
Postby xbox360 » Fri Jul 07, 2006 10:20 pm
Just been looking at the ford website they have the MK 7 Transit on there now. I am wondering has the MK7 140ps 375Nm engine replaced the MK6 137ps 375Nm or has it been renamed :?
xbox360
Postby xbox360 » Fri Jul 07, 2006 10:26 pm
holy s*#t you can now get a 2.4 TDCi SWB 140 ps 375Nm front wheel drive :twisted:
xbox360
Postby AndyG » Fri Jul 07, 2006 10:27 pm
xbox360 wrote:holy s*#t you can now get a 2.4 TDCi SWB 140 ps 375Nm front wheel drive :twisted:
Where did that come from :shock: :?:
Postby Phil_G » Fri Jul 07, 2006 10:30 pm
waste of HP i think..
To justify that power in a van you will be pulling big weights and when you get big weights in the back of the can the front wheels will be picking up slightly thus reducing traction. our SWB 100 t280 does this to an extent!
I much prefer the idea of RWD commercials.
Phil_G
Postby xbox360 » Fri Jul 07, 2006 10:34 pm
You can have rear wheel Drive as well if you want
xbox360
Postby AndyG » Fri Jul 07, 2006 10:37 pm
Just a min :!:
Are you sure :?:
I thought the MK7 FWDs were now 2.2s :!: :? :?:
Postby xbox360 » Fri Jul 07, 2006 10:39 pm
Just a min :!:
yes sorry your right i have read it wrong the 2.2 TDCI front wheel is 130ps 310Nm :oops:
Are you sure :?:
xbox360
Postby AndyG » Fri Jul 07, 2006 10:40 pm
It's been one of those days today :roll: :lol: :lol: :lol: :lol:
Users browsing this forum: Rollingbob
