i was almost going for yellow, but no matter what shade of yellow you get, it will look like an AA van, same with Orange and RAC.
im spraying my van with Rustoleum, bought the paint in 2.5L tubs, thinning it down and using a compressor, although the finishes are almost identical after one coat. i think buying aerosols will take ages, and i somehow have it in my head buying 100 tins might lead to different shades, where i can mix from a big tub.
anyway, since last update i have done some filling, using 2part filler i got from Autosave Components. it looks pretty bad on photos, but i will build up layers and sand smooth obviously. not much more to be said because struggled with weather.
rear door, had a dent above handle when i bought it, and a big dent where i reversed into trailer hitch that was too high. and you can see some bits everywhere i used the rest of filler on. it looks like a dent on left door but its just reflection.
behind the SLD there was a small hole, i was told to cut it out and patch it, but that seemed too hard for me
i cut out rust that was 'loose' treated it with stuff i got from another motor factors, and filled over.
i removed badges for painting, and decided to fill over badge, just because i decided to at the time!
this one needs loads of coats of filler cause it was so deep.
im on backshift this week, so i might start painting this week and leave sitting for the rest of day while im at work, sand down the following day, depending on how things go, i have a long weekend soon but im hoping to use that weekend for finishing it.
bought new mirror covers off ebay, i had put indicators on my mirrors, but some D*** smashed mine when i was parked so bought 2 new ones from ebay, £10each.
new lights for roof bought the other day too, just the 6inch Ring ones i had on before, but they had been painted white so they are going on my brothers van as work lamps on rear.
I don't switch my lights on... I turn the dark OFF!
